Results 1 to 6 of 6
Thread: 12" combo cab for a AB165 Bassman.
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,419
    Received: 548/0
    Given: 100/0
    9
    I want to build a 12" open back combo cab for an AB165 Bassman I rebuilt. I have the original head cab, it's pretty rough, but I can still use it for some of the dimensions. It is approx. 22" wide and 9.5" deep, question is how tall should it be? And will that dimension effect tone much? I plan to use pine for the box, and baltic birch for the baffle.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Make a new cab, same width, depth and "wooden rails to hold chassis" as current head, reserve same internal height for amp, including iron, tubes, etc, and add enough for a front speaker panel, same width plus 12.5" for speaker frame plus 2" height so you can vertically center speaker and have *some* wood joining left and right halves (most of the center will be the 12" speaker hole).
    It will be a very compact and luggable combo.
    Optionally you might add extra 1" or 2" height, your choice, combo will still be compact; and/or up to 5" extra depth if yopu want sound slightly fatter but combo still fitting in a standard car trunk with room to spare.
    If in doubt make it 1/2" too large than 1/2" too small.
    EDIT: I would turn both channels (which as-is have no sparkle at all) into 2 standard Blackface "Normal/Guitar" preamps.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,399
    Received: 1,417/21
    Given: 1,207/0
    14
    Juan's got some good ideas as always. Let me pitch in a couple too. I had a customer recently who brought in a sort of Frankenstein combo, the amp was a standard BF Bassman, the cab I think was a 1x12 brown Vibrolux. You could check dimensions, and if the Bassman's width matches the brownie VLux, it should be simple enough to find the plans for that cab and build it.
    What to do with that bass channel? Not many guitarists like it much. I'd alter it with a 5F6A Bassman tone stack, optional mid control taking the place of the low-sensitivity input #2, or on the back panel. This way you'll have a choice of preamp options, both of them good.
    Old Timer
    Chill-Ville, VA
    3,183
    Received: 683/6
    Given: 1,335/9
    18
    I tend to leave these Bassmans and all that follow alone, as far as topology goes - the channels share the same number of gain stages (2), with that 3rd stage shared. And that 3rd stage (according to legend and internet lore; I don't have a scope to verify) is part of what sets these apart from other Bassman heads. So, a patch cable, and you can dial in some super-phat tone with just a patch cable. Tweak the tone stack to liking, but, why everybody gotta mess with these?
    One notice: mine has a Twin Reverb OT... Otherwise, it's pretty much stock.
    BTW: 12" combo for these heads are KILLER.
    Justin
    Jan 2013
    Cape Coral, FL
    2,419
    Received: 548/0
    Given: 100/0
    9
    "I had a customer recently who brought in a sort of Frankenstein combo, the amp was a standard BF Bassman, the cab I think was a 1x12 brown Vibrolux. You could check dimensions, and if the Bassman's width matches the brownie VLux, it should be simple enough to find the plans for that cab and build it."
    They don't match, the Vibrolux is narrower according to Fender Field Guide.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,436
    Received: 2,413/4
    Given: 2,796/0
    30
    There are always ways around a retrofit. I recently had to mate a chassis that was narrower than the cabinet opening, but matched the depth well. So I made thin panels that I Tolexed to match the cabinet and take up the gap. I used self stick Velcro on the back of those panels and at the wide ends of the chassis to make it look like the cab was built to match the chassis. Worked a treat.
    Like this:
  1. 5f2a amp, 5e3 cab: 10" or 12" speaker?
    By Sneakers in forum Build Your Amp
    Last Post: 09-05-2017, 07:33 AM
  2. Need to replace a 12" bass cab speaker... What one do i get
    By blindboybenton in forum Theory & Design
    Last Post: 07-18-2013, 07:06 PM
  3. difference between "Bassman 5F6A" and "Bassman 50"
    By carrejans in forum Vintage Amps
    Last Post: 07-16-2010, 06:58 PM
  4. Adapting a Tweed Princeton Cab for a 12" Speaker
    By slohand42 in forum Cabinetry
    Last Post: 10-25-2009, 10:52 PM
  5. 12" and 10" in the same cab?
    By Mostro in forum Cabinetry
    Last Post: 06-17-2009, 04:57 PM
