Results 1 to 5 of 5
Thread: Tremolo effect pedal build
    Sep 2012
    Poole UK
    597
    Received: 7/0
    Given: 12/0
    Hi
    I want to build a tremolo pedal for my own use
Name:	Vibracaster 12AU7 V2.jpg
    I have built it and it works, But not as well as i hoped
    The main problem is the depth. When i turn it fully off it increases the volume and only starts to work at about 12 o'clock
    The speed is better but i would like it to be more controllable, again it dont really work much until 12 o'clock
    I have made it exactly to the circuit
    I was going to try audio taper pots, but before i rip it out any idea's
    BBB
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 22/0
    Given: 2/0
    If it only starts to work at 12 o'clock with linear pots then with log it will be worse. With linear, 1/2 rotation is 50% of the resistance, with (most commercial) log pots this equates to 10% of the resistance.
    Try wiring up a log pot backwards to simulate a C taper pot. If that works OK either leave it like with reverse-operation controls, or order some C taper pots.
    The volume shift is a characteristic of the design. Amongst other things the NFB changes due to the varying cathode resistance - more NFB as the depth increases, so lower effective gain.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,854
    Received: 913/5
    Given: 942/0
    I can't look at the circuit and determine how it sounds. Is this a known good circuit. "Known good" being relative. As in did some guy say he made this and it's good or is it a popular design that is known? Many tremolo circuits use reverse audio pots. It's possible the behavior is "normal" with linear pots. The increase in volume with the trem off is a problem to be sure though. If you have a scope you can monitor signal swing to see if the trem is biased a little cold relative to when it's off. Properly, the trem will be a bit hot on peaks and, obviously very cold on the low volume or off modulation.
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 22/0
    Given: 2/0
    See post #222 here to reconfigure the depth control and add a cathode bypass cap (to remove the variable NFB, though the post refers to this as an anti-pop cap);
    Vibracaster - or "How to turn your Valvecaster into a Tremolo"
    Sep 2012
    Poole UK
    597
    Received: 7/0
    Given: 12/0
    Thank you. I will look into the changes
    BBB
  1. Tremolo effect idea - already been done?
    By Mark Lavelle in forum Music Electronics
    Last Post: 04-20-2017, 12:31 PM
  2. we use subminiature in effect pedal
    By kldguitar in forum Guitar Effects
    Last Post: 10-09-2011, 02:12 AM
  3. 1950's tube effect pedal
    By shzmm in forum Guitar Effects
    Last Post: 05-29-2010, 08:44 PM
  4. Ac30 clone - tremolo effect when goes off
    By bluemonk in forum Debugging Your Build
    Last Post: 10-04-2009, 08:05 PM
  5. new squeezer effect pedal
    Last Post: 04-19-2009, 03:09 AM
