Bassman aa864 clone noise
Welcome to the place and nice looking build!
Pulling V2 is nearly the same as disconnecting it's cathode. Either way, you stop the tube from conducting, so I'm not surprised results are the same. What about V1? If you pull that does the noise stop? By pulling V2, you've eliminated everything passed that, but it could still be anything before that. First thing I'd do is try tube substitution with known good tubes. You could simply have a bad tube. Double check your solder connections on the sockets."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
cathode voltage is high for me,in general its around 1,5V.same as the anodes at 290.
When there is hum i always go to grounds first,other things are filament heater balance and proper phase in the output tubes.
Did you also connect the ground switch?Last edited by alexradium; 11-17-2017, 12:35 PM.
