Results 1 to 3 of 3
Thread: Where does the gain stage end??
    Jan 2014
    Chiraq
    882
    Received: 120/5
    Given: 122/1
Name:	gain stage.jpeg
    It seems reasonable to think that the .02uF cap decouples the firs stage and the 2nd stage, so the plate side of the cap and everything previous is the 1st stage and the the grid side of the cap would be the beginning of the 2nd gain stage. I guess it also seems reasonable to think that everything preceding the 2nd triode is the first gain stage and the grid of the 2nd triode is the beginning of 2nd gain stage. But which one is it?
    What's the proper place for this ground is why I inquire.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,939
    Received: 892/5
    ground the grid resistor with its cathode resistor companion. Use the second triode ground.
    The 0.02uf cap COUPLES the two stages, not decouples. Decoupling is what the B+ "filter"cap does.
    Jan 2014
    Chiraq
    882
    Received: 120/5
    Given: 122/1
    case closed I appreciate it
  1. Dirty/Harsh top end in high gain amp
    By GainFreak in forum Build Your Amp
    Last Post: 10-05-2018, 04:59 PM
  2. Replies: 5
    Last Post: 12-06-2016, 06:59 PM
  3. Gain stage question?
    By Rod in forum Guitar Amps
    Last Post: 10-04-2012, 06:04 AM
  4. low gain on ef86 gain stage problem
    By black_labb in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-25-2012, 02:35 AM
  5. bypassing a gain stage
    By gtrboy in forum Guitar Amps
    Last Post: 06-03-2007, 05:25 AM
