Page 1 of 3 123 LastLast
Results 1 to 35 of 77
Thread: Vox AD120VT Problem
    Nov 2017
    Long Island, NY
    49
    Vox AD120VT Problem
    Hey all... I should say, I'm not a tech and don't really know amp circuits or electronics all that well. But I have a DMM, soldering iron and determination to try and learn if that counts for anything. I can somewhat follow the schematics.
    I have a vox AD120VT valvetronix from circa 2001. I liked it a lot actually, but after a few years it crapped out on me. I took it to a tech here on Long Island a while back, and he told me I shorted it out by dropping a pin onto the board (through the vents on the top of the unit). He wanted nothing to do with this thing is what I got from it... he told me go pick up a simple tube amp.
    I have done some research (searched this board, which has a few threads on it) and some other forums, and I get why he didn't want to work on it... nobody does, it's basically a computer lol. I'll try to keep this short, I know you guys like it to the point here.
    I took it out of the closet a week ago and turned it on. Everything lights up perfect as it did when I last powered it on. So for shits and giggles, I plugged in and took the effects loop send out of the amp into a small Roland cube 30 I play on for practice. It sounds great - so obviously the preamp section is fine.
    I plugged headphones into the phone out - nothing just light humming.
    The speakers and phone out have a low cycle hum which gets a bit louder as I move the power select switch, but overall it's not THAT loud.
    The speakers are fine and there is no DC current on the speaker out wires. (I've read to check that from someone on this forum).
    I have read that the headphone and other jacks can cut the signal it if the contacts are dirty. I have deoxit d5 on the way to try an clean all the jacks, but since the tech guy told me I shorted something.. I'm not counting on that being the problem. I never gigged the amp so it has no road abuse either.
    I don't have a scope, but I can build a small signal tracer probe to see where the signal cuts out if that's worth it. Maybe I could check continuity between all the switching. Not sure where to start.
    I opened this thing up and there is no burnt anything anywhere, looks clean as far as components, but I've also read the solder joints are garbage on this as well.
    Just looking for advice on what I could/should check out first, as maybe it's worth investigating since it seems to be in the power section.
    here's the schematics link that I'm looking at:
    http://www.valvetronix.net/docs/AD12...l_Complete.pdf
    Dec 2009
    Devon, UK
    2,895
    Received: 145/0
    Given: 119/0
    Plug your guitar into the return jack and see if you get anything out of the phone jack and speaker.
    If it works the return jack is the issue - simply plugging into it a few times is often enough for it spring back into life.
    Last edited by nickb; 11-19-2017 at 11:19 PM. Reason: Edited - was looking at wrong schematic
    Nov 2017
    Long Island, NY
    49
    Quote Originally Posted by nickb View Post
    The line/phone out jack sits right is fed from the return jack after a single chip buffer. Either the return jack contact is bad or the buffer is. Plug your guitar into the return jack and see if you get anything out of the phone jack and speaker.
    Hey nickb, thanks for checking it out.
    I just tried plugging into the return jack, nothing. I plugged the jack in/out many times... still nothing. before I do anything I'll be getting the cleaner to try with also.
    It seems the signal is gone maybe well before the line/phone jack, although I'm not great at reading this schematic. It seems the problem may start from Master Volume onward. Power Section is fed from the Master Volume W09 into CON1(R-IN) + CON2(L-IN) to the power PCB where it goes to the VN2410L's and on... looks like signal to the line/phone outs are after the valves right?
    Dec 2009
    Devon, UK
    2,895
    Received: 145/0
    Given: 119/0
    Standby... I looked at the AD100 schematic....
    Dec 2009
    Devon, UK
    2,895
    Received: 145/0
    Given: 119/0
    OK.. Ahem.. Looking at the correct schematic now
    Yes the return jack goes thru the master volume VR15 and on to the Q3/Q4 and Q1/A2 differential pair amps. Now since this is stereo and both outputs are dead it suggests something common like a power supply. I suggest you check the voltage on the center tap of the transformers for about 218V.
    Nov 2017
    Long Island, NY
    49
    Yes the return jack goes thru the master volume VR15 and on to the Q3/Q4 and Q1/A2 buffers. Now since this is stereo and both outputs are dead it suggests something common like a power supply. I suggest you check the voltage on the center tap of the transformers for about 218V.
    Yep, I'm thinking check the output transformers as well, will do. I was just looking them up, seems hard to find new ones (vox part# V904050013). Don't want to jump the gun though.
    Thanks for looking it over, much appreciated. I'll update once I go digging later this week.
    Nov 2017
    Long Island, NY
    49
    Ok I tried cleaning the jacks and as expected, that wasn't the problem. I propped the PA board up and started probing around underneath to look for some voltages and I'm not getting much on the output transformers, not even a volt. These are PCB mounted OT's with 6 pins on each side so maybe I'm doing it wrong, I just checked each of the 12 solder joints on each one. The Tubes are glowing though if that means anything.
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    If you don't have voltage to the output transformer center taps, check that 100mA fuse just off the orange wires of the power transformer. It should be near "TAG2".
    FYI: I don't think Nick was saying your output transformers were bad. He was just wanting you to check voltage there. That voltage comes from the rectifier circuit off the orange wires of the PT.
    Nov 2017
    Long Island, NY
    49
    If you don't have voltage to the Output transformer center taps, check that 100mA fuse just off the orange wires of the power transformer. It should be near "TAG2".
    Just checked it, those were the first things I looked at when I took the chassis out. They seemed fine but I just checked continuity on the F1 and got the beep.
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    If the fuse is good, check the voltage on the cathode of D11 or D12 (same point). It should read about 216V.
    Nov 2017
    Long Island, NY
    49
    Reading barely anything on D11 or D12, R84 gives me 195V right before them.
  12. #12
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    Your meter is set for DCV and not AC?
  13. #13
    Nov 2017
    Long Island, NY
    49
    AC on R84, DC on rectifiers right?
  14. #14
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    Yep.
  15. #15
    Nov 2017
    Long Island, NY
    49
    Yep.
    ok yeah, 13.1mV on the cathode side (side with the stripe).
  16. #16
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    Do you have AC on BOTH sides of R84 all the way to the anode of D11?
  17. #17
    Nov 2017
    Long Island, NY
    49
    Do you have AC on BOTH sides of 84 all the way to the anode of D11?
    195V on the top, .2V on the bottom of 84.
  18. #18
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    Check R84- 1K/1W. I believe it's open. You should also check those rectifier diodes for shorts. Check the 216V rail for continuity to ground to make sure there isn't something shorted on your rail. There's probably a reason that resistor went open.
    Edit: Also check that F1 is the correct value. It should have gone first. Maybe someone put a larger fuse in there? (assuming I'm right about the resistor)
  19. #19
    Nov 2017
    Long Island, NY
    49
    Check R84- 1K/1W. I believe it's open. You should also check those rectifier diodes for shorts. Check the 216V line for continuity to ground to make sure there isn't something shorted on your rail. There's probably a reason that resistor went open.
    Will do ASAP tomorrow. Thanks a lot for your help The Dude.
    The tech I brought it too over 10 years ago said I dropped a pin onto the board and it shorted... so it's starting to make sense here now that you say this. He just had no intention on trying to mess with the insides of this amp, I don't blame him.
  20. #20
    Dec 2009
    Devon, UK
    2,895
    Received: 145/0
    Given: 119/0
    Quite so. It was just a convenient test point.
    We're having a late night by the looks of things
    I was very, very surprised he didn't attempt some basic trouble shooting - having no 218V is a pretty simple thing to test for.
  21. #21
    Nov 2017
    Long Island, NY
    49
    What's up nickb... Yeah I don't know, maybe he did test it I'm not sure. He was a nice guy though, seemed like he was in his late 70's, old school electrical engineer, so I didn't argue. I figured he just didn't wanna mess with it. He showed me the pin it was one off of a dress shirt lol. Didn't charge me a thing of course.
    Anyway I tried my next feeble attempt at diagnostics in regard to what The Dude told me to check.
    Not sure how to check if R84 is open, I guess that means take it off the board and test it, but I might as well just get a few new ones if it's even suspect. There is not much AC getting by it at all, like .2Vac before the rectifiers so something definitely wrong there.
    I checked the rectifiers and they seem fine - I'm getting .523 V on diode check and 0L when I flip the meter leads around.
    And for the ground continuity check on the 216V line... (which I'm only getting 195V really, straight off that orange wire before R84) I don't get continuity to ground until I check after the D13 and D14 rectifiers on their anode side, not if I check right at TAG4 connection. Is that how it should be?
  22. #22
    Dec 2009
    Devon, UK
    2,895
    Received: 145/0
    Given: 119/0
    Quote Originally Posted by imf View Post
    The ground is fine. To check R84 just turn off and measure it's resistance. I agree with the Dude - it's odd that should blow before the fuse.
    195VAC is fine too.
  23. #23
    Nov 2017
    Long Island, NY
    49
    Oh ok cool thanks. Yep it's open, read 0L. I tried a couple other resistors and they read fine. I'll check the fuse for correct value now...
    here's a pic, it says "carbon resistor" on material list, is that carbon film?
  24. #24
    Aug 2012
    Great Black Swamp
    1,827
    Received: 71/0
    Given: 180/1
    From the apparent physical size of it, I'd think metal oxide. What's the wattage? Probably a 1W CF?
    Standing the resistor a little off the PCB will help if this has chronic heat issues. Catastrophic over-current, not so much.
  25. #25
    Nov 2017
    Long Island, NY
    49
    Hey eschertron, it's 1K/1W.
  26. #26
    Nov 2017
    Long Island, NY
    49
    BTW, you guys are good... The Dude was right... this is a T125mAL fuse in here... I'll be damned. Should be a T100mAL.
  27. #27
    Aug 2012
    Great Black Swamp
    1,827
    Received: 71/0
    Given: 180/1
    I think Dude had money on it being a 20A fuse
    1W carbon film aught to be right for that size resistor. What's its function? I haven't looked at the schem.
  28. #28
    Nov 2017
    Long Island, NY
    49
    lol - i'm worse than an amateur here, sorry guys.
    It's the resistor right after the 216V PT lead hits the board, right before the rectifier diodes.
    I got 1k/1w Xicon carbon film and some of the same in metal oxide at close to the same size at mouser. The one I pulled out is 3.2mm x 10.5mm something like this. Is there a preference for metal oxide in the power section over carbon film, or really not much of a difference?
  29. #29
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    The resistor composition makes little difference assuming the proper fuse is installed. Any 1K/1W would work. As eschertron suggested, I would leave the leads a little longer when you replace it and get it standing up off of the circuit board a bit to keep heat away from the board.
  30. #30
    Nov 2017
    Long Island, NY
    49
    Cool, will do as suggested. Thanks a lot everyone, I'll let you know how it goes after I get the components.
  31. #31
    Aug 2012
    Great Black Swamp
    1,827
    Received: 71/0
    Given: 180/1
    Is R84 even sized right? I calculate about 32mA is the failure point for this device. Why try to protect it with a 100mA fuse?
    P = I2R
    I2 = P/R
    I = SQRT(P/R)
    I = SQRT(1/1000)
    Am I off here? What's R84 even doing there?
  32. #32
    May 2010
    Sioux Falls, SD
    5,305
    Received: 255/0
    Given: 218/0
    FWIW, it's a T100mA (slow blow). I imagine the fuse is only there to protect the PT in case of catastrophic failure. Otherwise, there are lots of amps that don't have an HT fuse at all. Without measuring, we don't know what actual current is in the circuit.
  33. #33
    Aug 2012
    Great Black Swamp
    1,827
    Received: 71/0
    Given: 180/1
    FWIW, it's a T100mA (slow blow). I imagine it's only there to protect the PT in case of catastrophic failure. Otherwise, there are lots of amps that don't have an HT fuse at all.
    Worded poorly, I know. I guess I meant to ask, how is the fuse even going to blow first? I know the resistor will take a few seconds (or fractions of a second) to heat to damage, but so does the fuse. A direct short across the rectifiers, or some other catastrophic current failure, I see the fuse protecting the transformer winding. But a slower high-current failure (between 32 and 100mA) will always take out the resistor first.
    So my point is, if the bean counters didn't want to pay for a resistor sized to live through the short (yup, needs 10W plus to do that), why not ditch the fuse and leave the resistor as the sacrificial element? Would it not blow fast enough / reliably enough to save the tranny?
  34. #34
    Aug 2012
    Great Black Swamp
    1,827
    Received: 71/0
    Given: 180/1
    And having said that, since the resistor was probably collateral damage, are we any closer to finding the fault?
    edit: OK, I read back and see that a foreign object was dropped into the chassis? Was that the root cause?
  35. #35
    Nov 2017
    Long Island, NY
    49
    Could it have anything to do with me dropping a metal pin onto the board (fell through the vents on top)? No idea where it could have hit.
  1. Vox AD120VT Test Mode
    By dmeek in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-04-2014, 12:55 AM
  2. Weird VOX problem
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-27-2011, 02:17 PM
  3. Vox Valvetronix AD120VT power selector
    By Robert M. Martinelli in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-14-2009, 04:45 PM
  4. Vox DA15 problem
    By Ezro in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-28-2009, 10:13 PM
  5. Vox 847a problem
    By murphcc1 in forum Guitar Effects
    Last Post: 04-04-2009, 01:32 AM
