Results 1 to 16 of 16
Thread: Redplating Fender Super Twin Reverb.
    Junior Member
    Nov 2017
    8
    Hi,
    New here, but have had success in the past with other forums!! I have a '78 Fender Super Twin Reverb (blackface) that has a power tube redplating. I know it's a beast, and some say to put it out on the curb. But it's loud if not heavy. The first tube from the power side is redplating. I pulled the chassis, and the 2 resistors on # 3 are burned to a crips. Everything I've read pertain to 4 power tube amps, this has 6. So I want to replace the resistors and see what happens, maybe still redplating. I quess my question is where can I find replacement resistors?. RadioShack? Thanks, Mark.
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,781
    Received: 110/0
    Given: 16/0
    Antique Electronics Supply for all your amp needs https://www.tubesandmore.com/
    Or Mouser when you need to go a little deeper https://www.mouser.com/
    Consider replacing that tube.
    Junior Member
    Nov 2017
    8
    Thanks Randall, is it weird that the tube with the bad resistors isn't redplating? I've 2 new tubes!
    Old Timer
    Chill-Ville, VA
    2,717
    Received: 264/4
    Given: 558/11
    Just an FYI, don't let the cosmetics fool you: this thing is about as far from a BlackFace amp as you can get. It's not a Super "Twin Reverb." It's a "Super Twin" WITH Reverb. The first gain stage is different, the Tone Stacks are different, the output is different, etc. About the only thing it has in common with a Twin Reverb is the 2x12" speakers.
    This thing is more akin to the 400PS, 300PS, & PA160.
    Justin
    Dec 2008
    Wernersville, PA
    12,452
    Received: 181/2
    Given: 84/0
    Dec 2008
    Wernersville, PA
    12,452
    Received: 181/2
    Given: 84/0
    Quote Originally Posted by Mljbone View Post
    If the 470 ohm screen resistor is open, then the tube will not conduct.
    Hence, no red plating.
    Chicago, USA
    4,908
    Received: 60/0
    I never thought of the first gain stage cap making all that much difference; whenever i work on any of those amps I end up diode biasing that stage and making them all sound the same.
    I can't hang my hat on that treble cap in the tonestack making all that much difference either. Yeah, it's different, but not like it's night and day.
    I always thought that the additional gain stage is what made the preamp different, in a way that isn't particularly that appealing. What else is different? Perhaps most significant to me is that the STR is a single channel amp that lacks tremolo, while the TR is a conventional Fender dual channel tremolo amp. That tremolo difference is HUGE!
    The STR is an amp that appeals to an entirely different kind of player than a BFTR, IMO.
    Junior Member
    Nov 2017
    8
    Thanks for the input! I picked up 470 ohm and 1500 resistors to replace on that power tube socket. But they are 2 watt , I'm not sure if that makes a difference I think they need to be 1 Watt. Also is there a way to tighten up the power tube connections inside the socket, some of them look like they're open. I was told loose ones could cause my red plating problem. THANKS!
    Apr 2010
    Burbank, CA
    1,038
    Received: 219/1
    Given: 545/1
    When you look down the tube socket insets, are they wrap-around or fork-style terminals? The wrap-around type are easy to re-tension, using a very tiny bladed screwdriver to somewhat close down the opening without preventing pin insertion in the process. The forked terminals require a much smaller but stiff tool that can enter in the narrow slot that keeps them captive and aligned for mating with the tube pin. They're a bit tricky to bend in a bit in the attempt to make a tighter fit again.
    With regards to the wattage on the screen resistors, I normally use Metal Oxide power resistors. There are two sizes available for each wattage up to 5W. MO2 is the larger 2W body size, and MO2S is a smaller 2W body. A MO2S looks like a MO1 in size. The real difference is surface temperature under load. A MO2S will run hotter than a MO2
    Junior Member
    Nov 2017
    8
    Thanks nevetslab, they're wrap around.
    Jan 2013
    Cape Coral, FL
    1,781
    Received: 110/0
    Given: 16/0
    With regards to your resistor wattage question, you can always go up in wattage with resistors. A 1 watt is built to withstand 1 watt of power, where a 2 watt will withstand 2 watts of power, so in your case, not a bad thing to go to 2 watts.
  12. #12
    Junior Member
    Nov 2017
    8
    Thanks Randall!
  13. #13
    Junior Member
    Nov 2017
    8
    So I replaced the resistors on the 3rd power tube socket. Plugged the head in to check output on pin number 5 on all sockets. Started with the first 3 with -53.6v the others at -49.1v. Waited a minute or two and went back to check output. They climbed up to -59.1v and -53.4. Then the resistors on first socket zorched and the fuse burned out. This socket is the one with red plating issues. Any ideas?
  14. #14
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,941
    Received: 892/5
    You have an obvious arc, if there were no tubes. The resistor has no circuit, it goes to a socket pin and stops. Even with a tube in the socket, it goes to a grid, which is a wire hanging in space. To get that resistor to burn up, it has to have current from somewher, and most likely is pin 4 next to is, several hundred volts different. I'd replace that socket.
  15. #15
    Junior Member
    Nov 2017
    8
    Thanks for the information Enzo!
  16. #16
    Junior Member
    Nov 2017
    8
    I replace resistors, cleaned and tightened up terminals on sockets. No redplating, amp sounds "great". Thanks all for the help!
  1. Fender red knob twin vs Fender twin reverb 65 reissue clean channel with Les Paul
    By jalexquijano in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-20-2017, 03:34 AM
  2. Add Line In: Fender Super Twin Reverb?
    By tbryanh in forum Theory & Design
    Last Post: 01-06-2014, 05:27 PM
  3. Fender Super Twin Reverb with 6 6l6gc's
    By Jay D in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-26-2011, 11:05 AM
  4. Super Twin Reverb
    By imaradiostar in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-02-2010, 01:17 PM
  5. Super Twin Reverb Mods
    By joethefenderdude in forum Mods & Tweaks
    Last Post: 10-26-2006, 05:04 PM
