Results 1 to 10 of 10
Thread: BEDROCK 1400
    Oct 2012
    Austin, TX
    70
    8
    BEDROCK 1400
    Hey guys, been away for a while. So I have this Bedrock 1400 head on my bench. There's very little info on these amps, certainly no schematics that I can find. So my first question is, anyone have a schematic for this thing? And secondly, when the guy brought it in, he had blown tubes and had a bad input jack, and filter caps from 30 years ago. So I replaced these things. Didn't do anything crazy, just your typical maintenance. He brought it back 4 months later saying it stopped working. I once again have it on my bench. One of the 2 power tube sockets (EL34's) is eating tubes. I cannot for the life of me figure out why. The design of these things is pretty standard Fender/Marshall style, but laid out very tech-unfriendly and annoying. One thing I did notice was that the PT has a heater CT, and there is also an artificial/elevated CT on the power tube sockets. I disconnected the artificial CT resistors, but I can't tell if this has solved the problem. What happens if PT CT and artificial CT are used at the same time? And what else should I be looking at to understand why one tube keeps getting destroyed? Can Anyone shed ANY light on this? I'm happy to elaborate and provide pics and more info.
    Nov 2013
    303
    Received: 117/11
    Given: 38/0
    6
    Pics and voltages.
    If there is only one secondary for all the heaters you only need one reference, be it ground or elevated, your choice.
    Dec 2008
    Wernersville, PA
    12,921
    Received: 521/3
    Given: 275/0
    26
    Here is what I have gathered up on the Bedrock amps.
    Bedrock.zip
    The drawing of the heater circuit shown on the 1400 is misleading.
    It is drawn a bit clearer on the 1200.
    Both show 100 ohm hum canceling resistors on the center tapped heater winding.
    Dec 2009
    Devon, UK
    3,560
    Received: 757/1
    Given: 599/1
    13
    My first suspect would be a bad contact on the grid 1 pin. Clean, retention and monitor the cathode current to see if it's fixed. The other possibility is that the socket is damaged from arcing. If that is the case replacement is the only option.
    The redundant heater resistors will have no affect on this.
    Dec 2008
    Wernersville, PA
    12,921
    Received: 521/3
    Given: 275/0
    26
    Check out these young rockers!
    Oct 2012
    Austin, TX
    70
    8
    So those 100 ohm resistors can stay put, even though the heater wires have a CT?
    Oct 2012
    Austin, TX
    70
    8
    I'm unable to open that zip file
    May 2010
    Sioux Falls, SD
    6,321
    Received: 1,219/1
    Given: 945/1
    16
    Those resistors have been in there since the amp was built, so I don't see why you should worry about it. Also, the zip file opens fine for me so the problem must be on your end.
    Oct 2012
    Austin, TX
    70
    8
    Cool. I'll check those things. I have extra tube sockets if it comes to that.
    Feb 2010
    11,739
    Received: 1,607/23
    Given: 4,112/11
    22
    The zip worked fine for me too. Maybe try it again.
  1. Bedrock 1400 head schematic needed
    By Redline in forum Schematic Requests
    Last Post: 04-25-2017, 08:47 AM
  2. Bedrock 1400 head tone stack not working
    By Redline in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-21-2017, 12:59 PM
  3. QSC 1400
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-19-2016, 03:50 AM
  4. QSC 1400
    By Techknowman in forum Other Amps
    Last Post: 12-20-2011, 02:43 AM
  5. QSC 1400 Question
    By Techknowman in forum Music Electronics
    Last Post: 09-20-2010, 09:56 PM
Tags for this Thread
