Anyone tried a post phase inverter master volume in their 5e3? I'm wondering how much distortion actually comes from the PI. Thinking about trying the matchless spitfire type of master volume. Comments?
5e3 master volume???
Viewing the audio signal from both coupling caps out of the PI, the signal is distorting before the power tubes are.
That's why cleaning up the PI balance and using less bass or gain in the preamp sections can make the amp seem cleaner to a degree but still go into massive tweed 5E3 distortion anyhow.
I don't like the cross cut MVs.
Originally posted by playafndr View PostThanks Bruce. Would you recommend something similar to this instead?
http://blueguitar.org//new/schem/misc_mod/pi-m-vol.pdf
Just because I don't like cross cut MVs doesn't mean you or other don't too.
I'd just try the cross cut one first and see if you like it.
Use a 500K 12%-20% audio pot and a .047uF cap.
