Results 1 to 9 of 9
Thread: Help! Champion 600 Power switch issue
    New Member
    Nov 2017
    6
    I picked up a champion 600 with extremely busted power switch. Someone suggested that I could cut off the clips and put on a standard Carling switch. But I donít know where the four wires go and if the green wire needs connected to one of the three poles can someone please tell me what to do via the picture I posted? Time is of the essence!
    New Member
    Nov 2017
    6
    It’s a carling 3 pole switch I just need to know where I attach the white and black wires. Which pole is which and is one of the poles a ground I should jump the green wire to or just black/black on pole 1 and white/white on pole 2... dig?
    Dec 2009
    Devon, UK
    3,013
    Received: 285/1
    Given: 271/1
    That switch won't work. You need DPST type.
    New Member
    Nov 2017
    6
    That stinks... I’ll hunt one
    New Member
    Nov 2017
    6
    Thank you though!
    New Member
    Nov 2017
    6
ID:	45876Click image for larger version.
    New Member
    Nov 2017
    6
    When I do get it, which Poles does the power cable go to which poles do the interior wires go to?
    Lest We Forget g1's Avatar
    Feb 2010
    10,428
    Received: 592/21
    Given: 1,309/5
    The green of the AC cord does not go to the switch. It is supposed to connect directly to the chassis with it's own bolt.
    The white and black from the AC cord should go to the 2 end lugs of the switch. The other white and black should go to the center lugs.
    The 2 whites should be on the same side of the switch, same as the 2 blacks. (not criss-crossed)
    Feb 2010
    10,428
    Received: 592/21
    Given: 1,309/5
    Here you can see where the green wire should be screwed to the chassis.
  1. Troubleshooting a Champion 600
    By Elias Graves in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-10-2013, 02:02 PM
  2. Champion 600 isn't working
    By rg7120 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-04-2012, 12:43 AM
  3. Fender Champion 600 On/off toggle switch
    By Parktreeone in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-05-2011, 05:53 PM
  4. Fender Champion 600 Switch
    By Champion in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-30-2008, 06:02 PM
  5. New Fender Champion 600
    By Brad1 in forum Mods & Tweaks
    Last Post: 04-18-2008, 09:13 PM
Tags for this Thread
