Results 1 to 1 of 1
Thread: Sunn 1200S Restored/Revised amp with new Schematic
    Apr 2010
    Burbank, CA
    1,694
    Received: 588/1
    Given: 1,396/1
    11
    This just highlights the end result of a 1200S Restoration project that I began in mid-Nov 2015 and completed in late May 2016. Details are in the 1200S Restoration Project thread found in the Maintenance, Troubleshooting and Repair category. A couple weeks ago, I finally got around to creating a new updated 1200S schematic with the revisions, and have added thiat to this post.
ID:	45902 Click image for larger version.
ID:	45903 Click image for larger version.
    The above are outside views, after thorough cleaning of the chassis surface, getting all of the crustiness off, as best I could. you'll see all that in the other tread.
    The insides after restoration and upgrades have new supply filters, added a second bias pot so each pair of output tubes have their own bias adjust. Added Hum balance. Revised the previously non-grounding input jacks with a pair of switching transfer jacks (Switchcraft type 13A) and the usual type 12A jacks, so the 'bright' input networks are still there as well as non-filtered inputs, now set up with 0dB and -6dB input levels typical of Fender and other amps. Circuit is in the new schematic
Name:	Chassis Inside-Revised -55.jpg
ID:	45905 Click image for larger version.
Name:	Chassis Inside-Revised -54.jpg
ID:	45906 Click image for larger version.
Name:	New  input jack wiring-2.jpg
    The LDR Cell for the Tremolo circuit was moved off of the Tremolo PCB into a mu-metal and brass enclosure and installed between the Volume and Treble pot, moving it's high impedance out of the high hum field of the power supply/power transformer. The single transistor Reverb Return circuit was scrapped, now using a TL071 op amp circuit to mix the reverb tank back in, with the voicing in the Reverb path adjusted to taste. A lot more power supply filtering was added to the half-wave rectifier filter circuit that runs the Tremolo and Reverb circuit from the original.
    I replaced the original Gibbs reverb tank with an Accutronics 4AB3C1A, as the Gibbs was sounding very dark and murky.
ID:	45908 Click image for larger version.
    The re-composed and revised 1200S schematic follows.
    Sunn 1200S Guitar Amp-3.pdf
  1. Sunn 1200s hum
    By tdlunsfo in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-23-2017, 09:13 PM
  2. Sunn 1200S Restoration project
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-21-2017, 08:20 PM
  3. Sunn 1200S PA distorting
    By Nyqusit5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-03-2015, 04:22 PM
  4. Sunn 1200s bass amp scematics
    By doktorvacuum.se in forum Schematic Requests
    Last Post: 07-21-2011, 04:02 AM
  5. Sunn 1200S
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-15-2010, 12:03 AM
