Page 1 of 2 12 LastLast
Results 1 to 35 of 39
Thread: Acoustic 370 troubleshooting help needed
    Junior Member
    Dec 2017
    Jacksonville, Florida
    19
    I own an Acoustic 370 (with original 301 cabinet) which failed a few weeks back.. The output to any speaker cab and from the monitor outputs to a power amp produces weak and broken up (crackling) output. I've already taken it to one repair shop which evaluated it as not repairable due to availability (or the lack thereof) of old transistors and diodes. I've asked for a list of what they think is the failed components so I can begin my own search.
    I have a little electronics knowledge but no test equipment other than a digital and analog dvm. I'm not willing to make this a "for display only" amp as it has been my main amp since originally purchased back in 1970 while playing in high school bands (yes I just aged myself).
    I would appreciate any help, advice, direction, information that will steer towards restoring my 370 to full operation.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,943
    Received: 892/5
    "Can't get transistors" is just silly.
    The line outs are from the preamp. So it would be the problem so far. Now the LAST thing I am is a replace all the caps all the time guy, but in an amp this age (over 45 years) all those little 1uf caps in the signal path are instantly suspect. But before changing them all, the schematic has DC voltages all over it, so go through the preamp and compare yours.
    I would also apply a steady strong input to the amp and follow it through teh preamp to see where it goes away.
    Cheshire, UK
    1,907
    Received: 191/3
    Given: 126/0
    Schematic
Name:	Acoustic 370-Schematic.jpg
    Lest We Forget g1's Avatar
    Feb 2010
    10,428
    Received: 593/21
    Given: 1,309/5
    As far as the transistors go, yes some of the exact replacements are obsolete. But there are perfectly usable substitutes available.
    30,943
    Received: 892/5
    Exactly, most any good small signal transistor of the right polarity should work just fine in the preamp so long as voltage spec is met.
    May 2010
    Sioux Falls, SD
    5,432
    Received: 427/1
    Given: 334/0
    And, since this is a single supply output section with an output coupling cap, don't forget to check C404.
    Jan 2017
    Croatia
    142
    Received: 16/0
    Given: 7/0
    Does the sound get loud during that crackling or stays weak?
    I had a similar problem with my Acoustic 230 a couple of months ago. The crackling would stop if I pushed the volume knob at a certain angle. After reflowing all the pots and cleaning them the amp came back to life.
    I'm sure the guys at the repair shop would check for something like that, but given their response, anything is possible.
    Senior Member Sowhat's Avatar
    Mar 2010
    San Diego California
    415
    Received: 7/0
    Given: 2/0
    Got one of those as well sitting in my shop collecting dust, the customer abandoned it when I told him it was beyond economical repair. That's a pretty harsh assessment but that's probably what the tech you took it to was trying to say. It's not that the parts are unavailable or even expensive, it's the time involved in making things right that eat right into the economics of this repair. You might get lucky with some De-oxit but Enzo is probably right as usual when he suspects the 50 year old caps, the silicon stuff is probably just fine.
    ... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
    Jan 2014
    Chiraq
    882
    Received: 120/5
    Given: 122/1
    Check all those heavy ass inductors and orange drops in the preamp board to see if one of the legs has broken the solder connection.
    Junior Member
    Dec 2017
    19
    Schematic
    Dave, Thanks for the schematic ... I have a couple other copies of this but yours is a bit clearer .... I also have a parts list for the power amp section but do not have that for the pre-amp section .... if anyone has that I would greatly appreciate it as well. Not giving up on this just yet!
    Junior Member
    Dec 2017
    19
    I do understand the response in a way .... and the economics of it. I can easily pick up a PF500 and sell my 301 bottom ... or perhaps a used Carvin which will run down to 2 ohm loads, but it isn't my 370. .... I spent a good part of Friday sourcing parts for the power amp section ... mostly the transistors ... and found pretty much all of them ... not having a parts list for the pre-amp ... I haven't gotten to that yet and am hunting that parts list (if anyone has one would appreciate it).
    It was cleaned and recapped about 15 years ago and a few transistors were replaced ... not sure which ones ... the entire job cost me a whopping $80 but it was done by a tech I was in the Navy with ... he moved to California or I would take it back to him.
    Right now I'm just sourcing parts ... and then will decide if it is economical ... and then decide if I can part with it. I've not used any other amp for any performance in all of my over 50 years of playing ... except recently here where I've been playing lead and acoustic ... but that is a different story ... it is just hard to part with something that has performed so well and has been the basis of my bass sound .....
  12. #12
    Junior Member
    Dec 2017
    19
    That is my thought as well ... nice thump still from the power amp section on power up ... once I locate a parts list for the preamp section I'll start sourcing parts ... based on the schematic it looks like some of the pre-amp transistors are the same as some used in the power amp section.
  13. #13
    Junior Member
    Dec 2017
    19
    Yup .. that was my thought as well ... and I never really dug into the electronics in all my years in the service ... had all the training ... not that it means anything ... took a lot of college classes ... not that it means anything either ... don't have the test equipment other than a few good dvm's ... ... that slows me down a bit. I know I can generate a steady tone and feed that to the input but tracing it may be fun without a scope.... not exactly what I would consider ideal trouble shooting.
    I don't think I can make it any worse unless I do something really stupid ... short short zap ... but the preamp section doesn't really rely on matched output transistors ... more of the power amp section where that comes into play. If I had to work there I'd definitely be at a disadvantage without the proper test equipment to find matching power trans.
  14. #14
    30,943
    Received: 892/5
    I am a little concerned over this parts list thing. Are you planning wholesale parts replacement?
    The parts are mostly identified on the schematic. The 49-23 transistors are house numbered, also called 480023, the lower left notes tell you about component sorts.
    What parts do you need to identify that a list would help?
  15. #15
    Junior Member
    Dec 2017
    19
    Brought my 370 home from the shop last night ... I'll definitely check on all the recommendations everyone has offered so far ... and continue searching for parts. My wife's stepfather was an engineer at the cape ... had a very nice scope and signal generator ... he passed away a few years back and I'm not sure my mother in law kept all that or sold it but going to check that out ... having a decent scope will help trace the signal path ...
    Thanks for all the input ...
    Needs ... which I haven't found yet ...: Pre-Amp parts list if anyone can point me to that
    Common sense?
    I'm not playing bass right now and it was one of our other base players that was playing when my 370 gave it up .... the guy actually feels bad that it happened while he was playing. I understand the age issue (not me the amp!) ... he though maybe he did something. I did my best to explain to him that it was a tank but stuff breaks ... especially old stuff.
  16. #16
    30,943
    Received: 892/5
    Again, what do you hope to find on a preamp parts list that we don't see on the schematic?
  17. #17
    Junior Member
    Dec 2017
    19
    Exact transistor numbers ... I see the the 2N4248 on Q102 but all the rest simply read 48 - 23' .... so are they all 2N4248 or something else ... Sorry but I go by I've always used parts lists to be sure when doing other repairs (not electronics necessarily) and I'm not an expert in amp repair ... but I have do some minor electronics repairs ... have a good set of low wattage irons and am a clean solder person ... never lifted a trace .... not that that means anything.
  18. #18
    Junior Member
    Dec 2017
    19
    Enzo ... sorry and thanks ... didn't see your earlier response on house numbered parts and no, I'm not considering wholesale parts replacement ... that would be ... building a new amp and costly. I just want to be sure I get the correct replacements ...
  19. #19
    Junior Member
    Dec 2017
    19
    BTW ... I probably would never have gleaned that information from the schematic .... not an expert you see ... and the sourcing of parts was my way of confirming what I thought and that was that the parts are available ... but I do believe it may have gotten expensive to pay for the repair. I don't know the tech as this is my first shot at a repair. This music shop was recommended to me by a friend ... and it was the same shop I visited some 15 years ago with was having trouble finding techs ... I just got the impression from the shop owner who was nice but a little overly confident and cocky ... that his techs were the best .... and their combined experience would find a solution. So much for that.... my initial discernment was correct ... overly confident and cocky.
    Anyway ... not to be disrespectful or anything but you are obviously more well versed in this area and I am not ... I am well versed in my area of work and sometimes make assumptions on things that I think others should know ... that is sometimes a wrong assumption.
    I do appreciate the help ....
  20. #20
    30,943
    Received: 892/5
    I am just being direct, no criticism intended.
    I don't have my Acoustic lookup handy, but the part number is easily translated. No, the 2N4248 and 48-23 are not the same, they would use the same indication for all same parts on the drawing. Also, looking at them, one is NPN and the other PNP.
    Apparently 2N2484
  21. #21
    Junior Member
    Dec 2017
    19
    And I'm being overly sensitive. I should have stuck to the electronics as a hobby when I changed career paths but a lot of life got in the way.
    Thanks for the additional info.
    Luck may be on my side. My wife's mom has a new boyfriend who was a cape engineer for 40 years (as was her late husband), has done amp repair and is a ham radio hobbyist ... has build a few base stations and antenna arrays. He has a couple of o-scopes, oscillator and other good diagnostic tools. He says he has lots of parts as well ...
    So we are going to spend some time over the holidays going through my 370 and see if we can track down where the signal goes bad. In general, it just doesn't make sense to me for an amp like this to be put on the shelf or sold for parts ... it has a legacy that newer amps can't match and I've not played a quieter more thumping (if not deadly) combination. So it is a bit of a refusal to surrender just because someone said it is hopeless or can't be done.
    I've spent most of my career in software and database development doing what others said couldn't be done but I tend to look at things differently ... anything is possible ... just depends on how determined you are.
  22. #22
    Junior Member
    Dec 2017
    19
    Enzo ... is the acoustic lookup something you could share ... once we get into this thing I'd like to be able to put together ... and here is that dirty word ... a "list" of what we will need if Lee doesn't have it on hand. More concerned over the transistors and not having biasing issues (stay original) ... and all that fun comparing of data sheets.
  23. #23
    30,943
    Received: 892/5
    I have an entire career of technical manuals and collected notes... in my storage locker. Pretty buried, and winter happened and we won't do much deep digging until warm returns to Michigan.
  24. #24
    Junior Member
    Dec 2017
    19
    Winter! What is that? Here in Florida we blink and it is over!
    You are forcing me to remember things long forgotten (that hobby I spoke of which almost became a career). This is the first (maybe second) schematic I've looked at in over 35 years ... maybe more.... and the first time I've had a need to try troubleshooting an issue. So I'm going to build myself a little audio probe to start with, check voltages, and then if I find nothing take a trip to the cape and visit an old NASA engineer! Should be fun ... and warm!
    OK ... stay warm ... I have good friends up in the Grass Lake area (west of Ann arbor). I love their pictures of them trying to stay warm! They just moved back to their home in Grass Lake after selling their home here in Florida. I grew up in St Louis area so I have an idea of what winter is really all about.
    Thanks .....
  25. #25
    Jan 2017
    Croatia
    142
    Received: 16/0
    Given: 7/0
    Quote Originally Posted by mkreutz View Post
    May I ask how did the amp fail?
    You should tap lightly on all pots to make sure it's not just a broken solder joint or something silly like that.
    PCB is mounted on a chassis via pots only which are soldered directly to the board; generally not a good idea with amps that reproduce low frequencies.
    Also, I had to bypass preamp out to power amp in because shorting jacks just weren't making contact anymore; I see you already tried that.
  26. #26
    Feb 2010
    10,428
    Received: 593/21
    Given: 1,309/5
    The 48-23 being a 2N2484 is something that is noted on the power amp parts list. That Enzo mentioned it does not necessarily mean there is a preamp parts list, or Acoustic parts lookup.
    That being said, you may have more luck looking for the pre parts list by board number, rather than model, in case the same board is used in some other model.
  27. #27
    Junior Member
    Dec 2017
    19
    Worked one weekend ... didn't the next ... amp wasn't moved to my knowledge in between ....
  28. #28
    Junior Member
    Dec 2017
    19
    Yup .. .see that in a lot of ACC schematics as well ... just opened the amp up last night and removed the pre-amp board for a visual/mechanical check and don't really see anything glaring. Hope to get back to it this weekend sometime to start checking voltages and then apply a signal and trace that. I did power it back up and the distortion/crackling gets louder as the volume is increased ...
    I thought it would be nice to have a component layout so I've been working on that using the digikey.com Schem-it tool. It is not a necessity but has been educational ... having to recall the resister color coding has been fun but there are great tools for that on the internet. It will just help me step through the signal chain and process things in my brain as I move from schematic to board... maybe ... read that as a double check I guess. Visual person.
  29. #29
    Junior Member
    Dec 2017
    19
    Checking voltages revealed low voltage at q101 (.432) and q102 (7.4) ... from there it was the same throughout the preamp. Didn't find a single voltage other than the source and the voltages at R144 and R145 to be at spec. Using a simple audio probe the signal fell apart at Q107 ... was clean up to and at Q106, quite a bit of an increase coming out of Q102. Need to go back and check Q107 again but the signal was very dirty, broken up from Q107 on. Not settled in it being the issue and it being something in between ... bias perhaps ... drifting resistors and bad caps ... current drain somewhere (leaky caps) effecting all the voltages ....
    Did notice the Mylar cap C111 at the midrange pot to be ... burnt orange? Like almost brown ... suspect. I have almost a full list of caps from the 1mfd on up put together from mouser and digikey (comparing prices) ... will start there and check biasing resistors along the way for drift.... and pick up a few replacements for the 2N2484 just in case. Has anyone replaced these using the TO-18 case? I'm wondering about the need to heat sink the case and room for that ...
  30. #30
    Junior Member
    Dec 2017
    19
    Enzo,
    I applied a 1khz signal and traced it all the way to the pre-amp output and never lost the signal. Keep in mind I'm just tracing the audio at this point and trying to find the breakdown point without a scope. When I applied a varying signal (brought up itunes and a song with a heavy bass line), it appears the signal goes to crap at Q107 ... base, emitter provide the same trashed signal unless I have the pin out wrong but it leads me to believe it is not really Q107. Output from Q105 and Q106 is good which doesn't leave a lot in between. I've been staring at the schematic (and know I need to go back through everything again) ... are Q107, Q108 & Q109 part of the EQ circuitry? The tech mentioned bypassing the EQ, pulling the signal off after C116 from Q105 emitter ... or is that a dangerous idea. I didn't really like the idea ... why have EQ if it can't be used kind of thing. I figure the power amp input would need to be disconnected from C130 and relocated to C116 do this..... ???
  31. #31
    Junior Member
    Dec 2017
    19
    This is one of those ... "wish I had half a brain left?" ... R132 (330K) biasing resistor at the base of Q107 is wide open. All the other resistors around Q107 tested within tolerance except R131 100K which is reading just a hair over 105.8K ... ordered up the lot anyway along with new electrolytics. Haven't pulled Q107 to test yet (it tested good in circuit). Want to correct the biasing issue first and then see what we have.
    I did jump around Q107 last night for a few seconds and everything worked well enough to drive the 301 cab way louder than the neighbors wanted to hear ... stress test ... and then a stress relief!
    If everything works out I'll order up caps for a complete recap job and check everything else along the way.
    Thanks for all the input from everyone. I am hopeful that correcting the biasing issue will fix the problem. This has been educational for a newbie ... or one who just forgot a lot.
  32. #32
    30,943
    Received: 892/5
    105k on a 100k resistor is only 5% off, probably the tolerance of the part anyway.
  33. #33
    Junior Member
    Dec 2017
    19
    Yup ... I don't know what I was thinking on that one (bad math late at night). Replaced open R132 (330K) at Q107 and the lytics C102, 127 and 128 just because I was in there. She is back! I've read that it is advisable to not just replace all the 1uF tants but to do so with lytics as well .... actually all the tants. I expect most everything on the PA board is ... 47 years in age at least except the lytics.
    There is a little oscillation (clicking) on power up which settles quickly (5 seconds or less). Noticed R144 and R145 fairly hot to the touch but the voltages check good there. All in all I played it for a while and then just ran tunes through it for about an hour with no issues. If I can get all the critters out of the house for a while tonight I will push it a bit harder (like above 2 maybe .
    I'm waiting on a loaner scope to see if I can track down the oscillation or clicking ... whatever it is. It lasts for a whole 5 seconds at most so I'm expecting a challenge there.
    Thanks again for all your input Enzo ... and encouragement. I am so tempted to call the music shop I took it to initially and ask if the tech even knew what he was looking at. Like ... Did he have a schematic and did he really trace the signal or just sit texting for a couple hours ... or something ... and charge me $75 bucks to say "it can't be fixed ... can't find the replacement parts." I've found nothing but options and information on this forum and the unofficial ACC forum ... and others! Supposedly the tech was "on two forums" per the owner ... sure ... not so sure I would recommend them to anyone but our options are few here in Jacksonville Florida. I might have suspected something was up when the shop owner began to bad mouth the other repair shops and brag about all the experience his techs had combined. Hmmmmm.
    I may have just gotten lucky on this .. who knows ... I did a lot of research (and reeducating), stared at the schematic for a few hours before touching the board. I'm not a professional ... just determined.
    So the (re)education continues ... here I am about to retire ... and relearning things long forgotten. I see some new toys coming for testing! Anyway, my plan is to breadboard the first few stages of the preamp (Q101 - Q102 and maybe through the tone controls) to the volume control and experiment with sub xters just for fun .... and then continue on.
  34. #34
    Junior Member
    Dec 2017
    19
    Was suspicious of how I had things setup and that I may just have a grounding issue ... the PA board was upside down so I could trace the input, pots snugged up to the mounting bracket which was connected to chasis ground with a jumper wire ... so I decided to clean things up and assemble it properly before giving it another test. Quiet as a mouse ... perfect ... ecept for that hiss at full volume which says it is going to hurt ... cranked it wide open and had some fun. This house has never been eposed to that!
  35. #35
    30,943
    Received: 892/5
    And as to contacting the old shop, what is to be gained by doing that? Just don't go there for service again, and tell anyone interested what your experience was there. The market will take care of itself.
  1. Acoustic 370 Amp Power Module Troubleshooting Question
    By olegeiser in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-28-2015, 03:54 AM
  2. Acoustic 370 troubleshooting help
    By poveglia99 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-12-2014, 05:15 PM
  3. Acoustic 370 troubleshooting
    By Grant in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-26-2013, 11:09 PM
  4. Acoustic 370 troubleshooting.
    By Grant in forum Music Electronics
    Last Post: 01-14-2012, 04:51 PM
  5. Cooked Acoustic 370
    By ianacousticbassman in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-20-2010, 08:12 AM
