Results 1 to 12 of 12
Thread: Tweed champ 5f2 pwr tranny swap
    Feb 2014
    New Jersey
    43
    Original tranny smokes and blows fuse with all secondary leads disconnected. Bought new unit, all is good save for the heater filament on the new tranny (magnetic components 40-18019). It's center tapped. Should I tape n tuck the center tap away and ground one side of the heater winding? Silly question, I should know this, figured I'd ask anyway.
    Thanks in advance.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,651
    Received: 579/1
    No, ground the center tap, not one side.
    Old Timer
    NYC
    1,654
    Received: 5/0
    I would scrap the old single wire heater scheme and rewire with the quieter twisted pair.If you are talking about a vintage 5f2 that you prefer to keep original,then yes,just disregard the CT and wire it like the original.Just saw Enzo's response,if he grounds the CT and uses just one side,he'll only get like 3+v's.
    Feb 2014
    New Jersey
    43
    Quote Originally Posted by stokes View Post
    So if I ground the center tap, I would need to lift the grounds on pin 2 on the 6v6 and pin 9 on the 12ax7, then do the twisted pair, correct?
    Feb 2014
    New Jersey
    43
    Quote Originally Posted by JMMP View Post
    Also, doing the heaters this way, how do you guys handle the pilot lamp (grounded to the chassis through the mount)? Seems easier to add the 2 100 ohm resistors, leave the CT tucked away and not attached, and ground one end of the 6.3v filament tap. Thoughts?
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    FYI: The pilot lamp connections are isolated by fiber washers.
    Feb 2014
    New Jersey
    43
    Not on this model, indicator is just another parallel filament connection, lamp body goes directly to chassis ground through mount.
    Feb 2010
    10,200
    Received: 346/1
    Given: 672/0
    Well, if you are not going to change the indicator, then you have to leave one side of the heaters grounded, no CT, no 100 ohm resistors.
    Feb 2014
    New Jersey
    43
    Correction, lamp is exactly as pictured there. One tab was rotated, bent and soldered to mount and I didn't look closely enough. Thanks for all the help!
    Feb 2010
    10,200
    Received: 346/1
    Given: 672/0
    Just to clarify about your question in post #5, you can't use the resistors and ground one side of the supply.
    You must choose only 1 of the three options:
    a) CT
    b) 100R resistors (virtual CT)
    c) One side of heaters grounded
    Feb 2014
    New Jersey
    43
    a) CT
    Got it G1, thank you. Gonna ground one side of the supply.
  12. #12
    Feb 2014
    New Jersey
    43
    Worked out great, Champ is now working as it should!
  1. Voltage Chart for the Tweed 5f2-a
    By marcbo77 in forum Debugging Your Build
    Last Post: 11-04-2009, 10:15 AM
  2. Stock 5F2-A Power tranny values?
    By ncusack in forum Tweed Builders
    Last Post: 08-01-2009, 08:53 PM
  3. Power Tranny Swap
    By ajeffcote in forum Mods & Tweaks
    Last Post: 02-16-2008, 07:38 AM
  4. More Pwr and Headroom for SF Champ
    By JPH in forum Mods & Tweaks
    Last Post: 08-11-2007, 10:24 PM
  5. More Pwr and Headroom for SF Champ
    Last Post: 08-11-2007, 02:55 PM
