Results 1 to 10 of 10
Thread: Fender Jazzmaster Ultralight - Power amp board
    Member lalunatech's Avatar
    Mar 2012
    Hadfield UK
    33
    Hiya all
    I have a Fender Jazzmaster Ultralight with a faulty power amp board. It looks like someone has had a go at it already. The eight power mosfets mounted (in a horrible way) under the PCB have no insulation from the heatsink, all their tabs are connected together. They are all the same N-Channel IRFZ24N which do not have isolated tabs. This is a mystery because I cannot see how it would work with high side and low side devices with their drain terminals shorted. I will try Fender for a schematic. Has anyone worked on one of these before? Has someone substituted an incorrect mosfet then given up on the repair before I got it?
    Thanks.
    Laluna Technology - www.laluna.co.uk
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,947
    Received: 894/5
    Do a search on this forum for that schematic, I think we posted it somewhere.
    Mar 2012
    Hadfield UK
    33
    Enzo
    It is OK, I emailed Fender last night and had them in my inbox this morning. I wish all manufacturers were so accommodating.
    BTW the power amp board (probably all the boards) are a discontinued Fender part now and they told me they don't have old stock in any of their warehouses.
    I normally don't attempt repairs on these horrible surface mount D-Class amp boards because they usually end in failure but I had a slack day and thought what the hell!
    Mar 2012
    Hadfield UK
    33
    Turns out the D-Class amp driver chip is faulty. It is just a piece of Jazz scrap now.
    Apr 2015
    101
    Received: 4/0
    Given: 2/0
    Would you care to share the schematic please?
    Something does not add up to me, mosfet type with mounting type you mentioned and power figure to be specific.
    What's the driver? IR2011, IR2110 or similar?
    30,947
    Received: 894/5
    30,947
    Received: 894/5
    Here, try this.
    The driver IC directly controls both channel MOSFETs.
    Attached Files Attached Files
    Apr 2015
    101
    Received: 4/0
    Given: 2/0
    Thanks a lot Enzo.
    And bloody hell, me so dislikes what me saw on the schem...
    And 250W, yeah, right on 2ohms load
    Dec 2008
    Wernersville, PA
    12,453
    Received: 181/2
    Given: 84/0
    "The eight power mosfets mounted (in a horrible way) under the PCB have no insulation from the heatsink, all their tabs are connected together. They are all the same N-Channel IRFZ24N which do not have isolated tabs."
    That is not good.
    (4) of them should have the Source grounded.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,413
    Received: 560/15
    Given: 456/13
    Agree and add:
    You bet.
    It did not leave Factory that way.
    See above
    It doesnŽt.
    Just peeked at bthe schematic , and that confirms my decision: I will never ever even try to repair such a "thing", period.
    Quite complicated, and it would be worth trying ... if the f*ck*ng thing cost, say, $3000 or $5000 so a used one would hover around, say, U$2000 so a $500 to $800 service charge would seem acceptable to owner.
    At U$800 over the counter new price, forget it.
    "hey .... but with that mentality eventually youŽll give up Servicing"
    ..... so what?
    What IŽd drop is unrewarding servicing ..... wonŽt miss it.
    IF I wanted to keep on, IŽd learn instead to service Avionis, Communications, Medical or Industrial stuff, even "smart house" Electronics , even "humble" modern car Electronics .... instead of dead end Musical Instrument stuff.
    Dead end because of automated manufacturing at virtual zero cost, which to boot lets designers complicate stuff as much as they want, in any case "it does not carry a cost penalty" so why not?
  1. Fender Jazzmaster Ultralight
    By schraedertr in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2013, 10:46 AM
  2. My fender JazzMaster has Hum :(
    By teepeeasel in forum Guitar Tech
    Last Post: 01-05-2010, 06:35 AM
  3. Anybody got a pic of the underside of a Fender Bandmaster Power Supply board?
    By StratTone in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-27-2009, 07:47 AM
  4. Out board power amp
    By nwguy in forum Debugging Your Build
    Last Post: 06-29-2007, 02:50 PM
