Page 2 of 2 FirstFirst 12
Results 36 to 54 of 54
Thread: Speaker baffle makers?
  1. #36
    Chicago, USA
    4,909
    Received: 76/0
    18
    I'm a dull tool and I cut myself all the time.
  2. #37
    Aug 2012
    Great Black Swamp
    2,255
    Received: 441/0
    Given: 1,176/1
    11
    sigh...
  3. #38
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,446
    Received: 2,424/4
    Given: 2,805/0
    30
    I've heard the "more likely to cut yourself with a dull tool..." thing too. We all have. IMHE though I cut myself a lot more when my knives are sharp (minor little cuts). I might say that since accidents are more likely with a dull tool due to clumsiness at higher pressures that you're more likely to stab yourself with a dull tool.
  4. #39
    Old Timer
    Chill-Ville, VA
    3,187
    Received: 686/6
    Given: 1,341/9
    18
    Depends on the implement being used at the time, of course...
    Some of the "dull tools are more dangerous" thing is the fact that a sharp tool ali leave a cleaner cut that is faster to heal and leaves less surface area for infection than a dull tool. Obviously this has more to do with knives and other "lacerating" tools, but there IS more rationale to this whole thing than the increased clumsiness of dull or worn tools...
    All that said, I find a very sharp chisel much easier to control than one that's shaped like a screwdriver...
    Justin
    Edit: then, there's pruning saws. No coming back from a nasty slice from one of THOSE... Sharp AND jagged.
  5. #40
    May 2007
    pacific north west
    15,446
    Received: 2,424/4
    Given: 2,805/0
    30
    Damn pruning saws! Frightening things. If you were to confront a blade wielding mugger with a knife or a big stick you might find yourself in a fight. But whip out a pruning saw and I bet they'd run like hell.
  6. #41
    Old Timer
    Chill-Ville, VA
    3,187
    Received: 686/6
    Given: 1,341/9
    18
    I was using one to cut a branch to sizeable firewood bits one day. I was still in the early stages, and got distracted. After a minute or two I found the blade sticking, on every stroke. I looked down to see why and nearly passed out. At some point the blade had l skipped, and I never felt any pain until I saw the saw, branch, and most of my hand covered in and dripping with blood...
    I've got my scars from those things... WEAR GLOVES!
    Justin
    Edit: I like your self-defense idea, Chuck!
  7. #42
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,156
    Received: 1,887/7
    55
    A sharp knife cuts right into a potato. A dull knife makes you press down harder, making the knife more likely to slide off the potato and across your finger.
  8. #43
    May 2007
    pacific north west
    15,446
    Received: 2,424/4
    Given: 2,805/0
    30
    So it should be: "You're more likely cut yourself with a dull blade than a sharp one if you're cutting potatoes in your hand instead of using a cutting board."
    Of course I get the concept. And it's accurate enough, I'm sure. Just not my personal experience. Perhaps some of us are just more likely to cut ourselves? I will say this, A dull knife is a sign of inexperience and a lack of respect for the tool and it's use. I think inexperienced users are more prone to accidents.
  9. #44
    32,156
    Received: 1,887/7
    55
    I put my potato on the board, hold it with my left hand and cut with my right. If the knife doesn't bite and slips off the left side, it will come down on my fingers. But I am belaboring the example and not the point, I suppose.
  10. #45
    Chicago, USA
    4,909
    Received: 76/0
    18
    of course we all know that the proper technique for cutting a potato (potatoe if you're republican) is that you curl your fingertips inward so that only your knuckles are exposed, and they are only exposed to the side of the blade. Chef School 101.
  11. #46
    Chicago, USA
    4,909
    Received: 76/0
    18
    found a video
  12. #47
    32,156
    Received: 1,887/7
    55
    Yes, curl your fingers inward. But that only works if you have the motor skills to prevent yourself from lifting the blade above your knuckles. That also assumes you are cutting straight down. When the knife slips off to the side, it assumes an angle, which can cut into the tops of your fingers or into your nails, even when they are curled.
    I lack those motor abilities, and so I carefully place each knife stroke. Never in a hundred years would I ever achieve the knife skills of Chef Morimoto.
    it is like shooting gold. Someone told me to take a little off my swing. Well, I have to have a swing before I can adjust it.
  13. #48
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,662
    Received: 354/6
    Given: 351/1
    12
    Have you tried "rocking" the knife with the tip on the cutting board, as shown in the vid? If your knuckles are touching the side of the blade, they can act as a guide to keep you from lifting the blade too high and cutting yourself.
    -rb
    DON'T FEED THE TROLLS!
  14. #49
    Feb 2010
    11,839
    Received: 1,671/24
    Given: 4,299/11
    22
    Come on guys, time to move into the 20th century already.
  15. #50
    Chicago, USA
    4,909
    Received: 76/0
    18
    Veg-O-Matic. I guess it's time to Get With the 70s. lol.
  16. #51
    Jul 2017
    British Columbia
    357
    Received: 5/0
    3
    ...have experienced jigsaw blade canter
    Am I the only one who thinks that "Jigsaw Blade Canter" would be a great name for a band? IMO it has the kind of unforgetableness (unforgetability?) that "Death Cab For Cutie" ( https://www.youtube.com/watch?v=mi6uRT7PxTQ ) has.
    I will freely admit that the words "canter" and "jigsaw" have never even entered my mind at the same time.
    -Gnobuddy
  17. #52
    May 2007
    pacific north west
    15,446
    Received: 2,424/4
    Given: 2,805/0
    30
    Quote Originally Posted by Gnobuddy View Post
    -Gnobuddy
    I was at the grocery store two days ago and they had these stupid huge kiwi (kiwis?). Someone at checkout mentioned their size and I interjected "Yeah, Chernobyl kiwi" which was met with some laughter. Knowing I had the floor I followed with "I was just taking the opportunity to say Chernobyl kiwi. How often does THAT come up?"
  18. #53
    Jul 2017
    British Columbia
    357
    Received: 5/0
    3
    Quote Originally Posted by bob p View Post
    When the Veg-O-Matic arrives, can the Super Bass-O-Matic '76 be far behind? https://www.youtube.com/watch?v=6RLHPaZUuyc
    -Gnobuddy
  19. #54
    May 2007
    pacific north west
    15,446
    Received: 2,424/4
    Given: 2,805/0
    30
    I was waiting for someone to call up the Bass-O-Matic. I resisted the urge. MMMmmm. That's good bass.
  1. Replies: 2
    Last Post: 12-10-2015, 05:35 AM
  2. Faceplate makers?
    By larams in forum Tools and Coil Winding Gear
    Last Post: 01-24-2015, 01:11 AM
  3. Need to make a speaker baffle board for a 70s Fender Super Reverb.
    By Modorange in forum Repair and Restoration
    Last Post: 01-20-2011, 04:10 PM
  4. Round over on baffle speaker hole?
    By bbmonster in forum Cabinetry
    Last Post: 01-13-2010, 08:19 PM
  5. Tweed Twin Speaker Baffle Mounting
    By erndawg in forum Cabinetry
    Last Post: 09-11-2009, 04:44 PM
