Results 1 to 5 of 5
Thread: Jazz PJ wiring issue
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,077
    Received: 18/0
    Given: 10/0
    I have a Jazzbass with the Precision bass pickup in the neck position & both pickups are wound so the P don't overpower the Jazz .& using the stock pot configuring v/v/t . but the problem I'm having is when both pickups are on full i get a drop in volume & treble & I don't think it is out of phase problems as I've reversed the wires of the jazz pickup & it still didn't correct the problem . Any one know a solution for this ? I've read one thread about "insertion loss" feel free to comment .
    Jun 2009
    2,077
    Received: 18/0
    Given: 10/0
    Really Nobody ? now i notice this with any jazzbass with both volumes at full you do get a slight treble roll off ..try it
    4,503
    Received: 116/0
    Given: 77/0
    I think it has to do with the mismatch of the pickups. If you get a better sound with one pot turned down a little bit (say to 9) you can add a resistor so that the pot never goes to 10.
    I noticed a similar effect when combining a series wired HB with a parallel wired one.
    Steve A.
    P.S. If you need help determining the correct resistor to add post your readings*** here and I will do the math.
    *** I'd need all 3 readings (1-2, 2-3,1-3) with the pot set to 10 and with the pot set to whatever setting works best. (If you can temporarily disconnect the hot leads it would be more accurate.)
    Chicago, USA
    4,908
    Received: 54/0
    Isn't this what they call "VVT Syndrome"? Loads of threads on it over at Talkbass.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,223
    Received: 308/0
    Given: 247/0
    Quote Originally Posted by copperheadroads View Post
    Had the same "problem" when I had a Jazz bass. One potential solution in the modern day, a simple FET preamp following each pickup, you could easily make yourself a copy of the old Alembic Stratoblaster for instance, then mix the pre outputs say with a couple 10K resistors.
    With the simple 2-pot mixer in the stock Jazz bass wiring, one pickup gets loaded down by the other when both are on 10 resulting in that loss of treble response. I s'pose you could sum the outputs of each volume pot with a pair of resistors, say 100K to 220K, but that would leave you with a high impedance output, an overall signal loss, and likely easier to pick up hum/buzz on the guitar cable. 3rd solution, same resistance mixer but feed that into a FET preamp within the bass. No easy way out without adding a battery.
    How's them iceburgs?
  1. PJ bass wiring problem
    By StarryNight in forum Pickup Makers
    Last Post: 04-04-2018, 09:27 PM
  2. PJ pickup
    By Rodent in forum Pickup Makers
    Last Post: 03-19-2015, 06:36 PM
  3. Pickup Wiring Issue
    By bjfly17 in forum Guitar Tech
    Last Post: 02-26-2014, 02:33 AM
  4. 5 String Jazz Bass Pickup Issue
    By TheGrateOz in forum Pickup Makers
    Last Post: 02-27-2013, 04:58 PM
  5. Fender Power Jazz Bass Special wiring
    By Axtman in forum Guitar Tech
    Last Post: 04-01-2008, 04:57 AM
