Has anyone ever had a problem when you turn on the standby switch it does not work ? Power light is on and when the standby switch is turned on it does not lite and no sound from the amp ??? Any Ideas what could cause this ?
Marshall JTM60 Standby Switch
I checked the main fuse and it was ok, I took the head out of the amp and there are 2 other fuses, one of which was hidden behind some capacitors.
When I checked that one and it was blown...
Thanks alot I did not realize the last on was hidden like that...
I'm not sure what amp rating the fuse is but I will get a acouple of replacements...
Thanks a million...
Originally posted by jets View PostI checked the main fuse and it was ok, I took the head out of the amp and there are 2 other fuses, one of which was hidden behind some capacitors.
Thanks a million...
Originally posted by jets View PostThanks trevorus, I would if I could... my eyes arn't what they used to be even with glasses.. I'll check with someone at the electric store and have them match it up..
Thanks Again..
If it is 500ma (1/2 amp) make sure it is a slow blow if that is what is needed. If it says "T500ma" by the fuse clips, T means time delay - slow blow. Often Marshall prints the fuse data on the circuit board near the clips.
And another warning: while it might just be a fuse that aged and failed, much of the time a blow high voltage fuse means a power tube failed.Education is what you're left with after you have forgotten what you have learned.
Enzo is right. It is a slo-blo.
Here's the link to the schematic: http://www.drtube.com/schematics/mar...00-61-02-1.gif
It's about in the center. The standby switch is labeled, and the fuse is right next to it, marked T500mA
Originally posted by TD_Madden View PostQuestion: Why would you want a slo-blow as the HT fuse? Didn't Marshall used to use a regular fuse there?
When you flip the standby switch to on, the caps all of a sudden have to charge, and that is a brief surge in current. With fast blow fuses, yuo need to have a fuse large enough to handle that surge. But then it is too large to really work as intended during operation. By using a slow blow fuse, we can use a smaller value fuse which is more likely to work as we desire.Education is what you're left with after you have forgotten what you have learned.
