Results 1 to 3 of 3
Thread: Using EL86 with EL84 OT
    Junior Member
    Apr 2017
    10
    Hi all... So, if I modify all the voltages in the circut to fit the EL86 but I don't have enough money for the new OT, can I use the EL86 with the old EL84 OT from the late 50's, and if I can, what would i have to do with the bias section and how should I adjust the bias so that the tube(EL86) handles a little higher EL84 plate voltage in the circut (don't worry for the screen grid, just bigger resistor) and that transformer that was not meant for that tube? Any opinions and posts would be very useful.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,687
    Received: 714/5
    Given: 745/0
    A brief glance at the datasheet suggests that the el86 is better with lower voltage, higher current and a lower Raa (primary impedance). Power is about the same so that's not an issue. You would need to know (or discern) the primary of the OT in question. And how much "higher voltage" are we talking about??? Further, a bigger resistor for the screen feed in the HV rail is "ok" but not ideal. You can quickly pigeon hole yourself into a very specific (and saggy) tonal character. This assumes you are building a guitar amp.
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Jul 2011
    Adelaide, South Oz
    693
    Received: 17/0
    What Chuck said.
    See the Class AB Push Pull specs on this datasheet:
    http://www.mif.pg.gda.pl/homepages/f...010/e/EL86.pdf
    The higher voltage (than +250V recommended for EL86) would require a higher Raa OT so the (almost certainly) 8K Raa for EL84 may be fine.
    Set bias for the idle current to be less than what the data sheet says by the ratio of the B+ you have with respect to 250V.
    Cheers,
    Ian
  1. Replies: 49
    Last Post: 10-08-2017, 03:45 AM
  2. Crate VC-3112 Combo 4 EL84 To 2 EL84 conversion?
    By Lostfollicles in forum Guitar Amps
    Last Post: 10-29-2013, 01:31 PM
  3. Replies: 2
    Last Post: 06-15-2013, 02:19 AM
  4. EL84 OT/impedance
    By EETStudent in forum Theory & Design
    Last Post: 02-16-2010, 08:20 PM
  5. Which OT for mixed el84/6v6 PP
    By allsavy in forum Theory & Design
    Last Post: 02-06-2009, 05:26 AM
