Results 1 to 4 of 4
Thread: Joyo Ultimate Drive Bypass Troubleshooting
    Jan 2007
    Cologne Germany
    24
    A few days ago I played around with my Joyo Ultimate Drive and recognized that if Level is turned all the way down, it not only cuts down the drive signal, but also the dry signal (pedal bypassed). The signal blends in from zero to about 8 o'clock, after 8 o'clock it remains on the same level.
    Of course this is not the normal working condition, but I'd like to fix this obvious malfunction.
    I thought it could be an unwanted ground connection, but the error persists even with the PCB removed from the chassis.
    Unfortunately I couldn't find a schematic, which includes the bypass-circuit. I read that the pedal uses the Millenium Bypass, but as far as I understand, this circuit is a true bypass with status LED realised with a dpdt switch, but there is a 3pdt switch used at least in my Ultimate Drive.
    So, I don't really know where to start...
    Oct 2015
    NEPA
    578
    Received: 46/1
    Given: 39/0
    Measure the resistances on the switch, chances are they are way above zero ohms when the contacts are touching.
    Jan 2007
    Cologne Germany
    24
    The switch seems to work properly, 0,3 Ohm on all 6 contacts depending on position.
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 13/0
    Quote Originally Posted by ruepselrum View Post
    There are two different Ultimate drive: what they are with real bypass and those that include a buffer. If your pedal is like this, it has a buffer included. No Millenium bypass in it.
    The written notes to convert it to real bypass are (from superior to inferior):
    - Extract the two capacitors
    - Desolder the orange wire from there
    - Connect it there.
  1. Fender Hot Rod DeVille & Deluxe Drive/More Drive mod
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-15-2018, 10:52 PM
  2. Can one bypass a PS choke for the purpose of troubleshooting?
    By Randall in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-11-2015, 01:10 AM
  3. joyo California no power
    By bkemker in forum Guitar Effects
    Last Post: 03-18-2014, 09:03 PM
  4. Fender Hot Rod Deluxe Drive/More Drive switching problem
    By ehouck in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-12-2013, 10:10 PM
  5. help troubleshooting fender ultimate chorus
    By guitar james in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-12-2008, 02:17 AM
