Originally posted by Chuck H
View Post
Safe to put V1a coupling capacitor on a switch for variety?
Originally posted by Mr. Bill View PostWait. Serious question. How is my drawing in post 26 different from Dave's drawing in post 5?"Take two placebos, works twice as well." Enzo
Just triple checking that I have my head wrapped around this. So if I go with Dave's switching idea since I have all those parts in shop, then follow that with a single mini toggle to take the 470k/500p in and out of circuit before the gain knob, I'm fine with the second switch because the .022 decouples the signal before any other switching? Here's my crude drawing. I really need to get a better grip on LTspice so my simulations actually work.
Further still, my switch to take the the .0047 in and out of the NFB loop needs nothing more than a switch since the cap on the presence knob is already isolating it from DC taking the scratchies out of the pot?Last edited by Mr. Bill; 01-07-2018, 04:29 PM.
Good to go on the three way switch. Connect the two way so that it shorts either end of the 470k/500p circuit together. Effectively "shorting" it rather than trying to bypass it."Take two placebos, works twice as well." Enzo
Too complicated. Think simpler
EDIT: Imagine the amp is built on an eyelet board (as I assume it will be?). You just have your parallel components in place on the board and run two leads from either end to the switch as shown.
And more to keep in mind. When adding leads in the signal chain that fly from the board to the panel you'll want to design your layout so that these leads can be kept short and away from like other phase circuits if possible. If you get too jiggy with switchable doodads and don't pay careful attention to lead dress you can end up with an unstable amp very quickly.Last edited by Chuck H; 01-07-2018, 06:08 PM."Take two placebos, works twice as well." Enzo
And... You mentioned having the three way switch on hand.?. If it is a three way toggle you'll want to be certain it's an on/on/on since those are sort of hard to find. Most three way toggles are on/both/on or on/off/on and would require more circuit consideration for wiring."Take two placebos, works twice as well." Enzo
I just found an SPST in the drawer, so that simplifies things and is less waste. I'm on mouser right now ordering some more along with some rotary switches. This is going to be one crowded chasis for sure. I think at this point I'm going to build it in a 4 hole box and eliminate the low sensitivity jack to make room. That'll give me 1 Jack and 3 rotaries in the 4 hole and I'll drill for a few mini toggles.
Like I mentioned above. It's a dangerous business running control leads back and forth across the circuit to the front panel. Controls should occur on the panel as they occur in the circuit as much as possible and layout should be designed to keep leads as short as practical. This is less critical in non cascade type vintage amps, but the 800 type circuit IS a cascade preamp AND you have a hotter cathode resistor in V2 which increases gain. Too much spaghetti and your amp will whistle like it forgot the words."Take two placebos, works twice as well." Enzo
I absolutely hear you on that one. If I eliminate the low sensitivity jack that I've never seen used anyway, then there is zero extra wire length to run the first two switchable mods. Those wires are already running to the face plate anyway. The depth switch, likewise can be right next to the Z selector needing no extra wire length or routing.
Quick silly question, maybe? Doesn't the 2203 cold clipping stage clip the negative lobe of the waveform? I'm Working in LT Spice as suggested by Chuck, and it seems to be clipping the positive lobe in my simulation. I guess dumb question #2 is....I'm supposed to probe the plates to see the output waveform of each stage, correct?
Originally posted by Mr. Bill View PostQuick silly question, maybe? Doesn't the 2203 cold clipping stage clip the negative lobe of the waveform? I'm Working in LT Spice as suggested by Chuck, and it seems to be clipping the positive lobe in my simulation. I guess dumb question #2 is....I'm supposed to probe the plates to see the output waveform of each stage, correct?If it still won't get loud enough, it's probably broken. - Steve Conner
