Does a low z single coil have the same s/n ratio (60 cycle only) as a standard single coil? ( 6k or so )
low z single coil and 60 cycle
Originally posted by Rosewood View PostDoes a low z single coil have the same s/n ratio (60 cycle only) as a standard single coil? ( 6k or so )
My experience is that low Z humbuckers sound pretty much like single coils.
When I switch mine to single coil, they do hum a bit.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Rosewood View PostSo David , you think that a true low z single coil hooked to an ic with gain set to equal a standard single coil output, the 60 cycle hum would be about equal on both pickups?
But I personally have no interest in single coil pickups. I think after 60 some odd years we should be able to make a pickup that doesn't hum and has good top end.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I think the reason I'm always thinking single coil is mainly to fit the single coil space. I have wound a few stacked coils that sound fair but they really lack dynamics, or at least that's what it feels like when playing them, too compressed. I was just curious if at some point towards low z if 60 cycle hum would be totally removed, that would be too easy.
Originally posted by Rosewood View PostI think the reason I'm always thinking single coil is mainly to fit the single coil space. I have wound a few stacked coils that sound fair but they really lack dynamics, or at least that's what it feels like when playing them, too compressed. I was just curious if at some point towards low z if 60 cycle hum would be totally removed, that would be too easy.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
