Results 1 to 4 of 4
Thread: Question RE Fender 5E5A channel
    Jan 2016
    23
    0
    Hi all,
    I'm planning on building a fender 5E5a circuit into a small old radio amp chassis with limited and already-determined restraints on the number of tubes etc. I want to add the tremolo circuit from a 6G3. I only have three nine-pin sockets to work with and don't really need two channels so my plan is to eliminate the normal channel and use the freed up half of its 12ax7 preamp tube to drive the tremolo circuit. This will allow me to stick with three nine-pin tubes.
    I have a few questions (see schematics)
    1. I'll be splitting the cathodes of the first preamp, which shares a 25/25uf cap and 820 ohm resistor. If I split this I'm assuming I should double the size of the cathode resistor, to 1500K or so?
    2. I take it I don't need to change the value of the plate resistor, correct?
    3. There was no ground shown on the schematic. Point #3 to ground, right?
    If there are any other things you think should be mentioned, let me know. And thank you!
    Thanks! Looking forward to figuring my way through this.
ID:	46452   Click image for larger version.
Name:	Screen Shot 2018-01-08 at 9.42.44 PM.png
    Chicago, USA
    4,909
    Received: 75/0
    18
    IMO: yes. yes. yes.
    Jan 2016
    23
    0
    Thanks Bob. Anything else need to be done, circuit-wise?
    Thanks,
    Ted
    Chicago, USA
    4,909
    Received: 75/0
    18
    I think you're all set with what you've got planned so far. It's a great circuit.
  1. Fender Blues Deluxe with no distornion and overdrive channel...channel switches fine
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-10-2017, 06:49 PM
  2. Master volume question- two channel fender
    By akimball442 in forum Mods & Tweaks
    Last Post: 01-15-2011, 03:49 AM
  3. Hum in 5E5A build
    By Bluefinger in forum Debugging Your Build
    Last Post: 03-22-2010, 12:29 PM
  4. Fender Twin Amp - Gain channel sucks, clean channel has limited Bass
    By TerryCline in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-16-2009, 06:45 PM
  5. Marshall channel in Normal channel of Fender reverb?
    By tubetonez in forum Mods & Tweaks
    Last Post: 02-21-2008, 06:59 PM
