Results 1 to 20 of 20
Thread: Hi-Fi Guidance
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Hi-Fi Guidance
    Hi folks, I am attempting to assist my brother who recently acquired a pretty nice 1968 Philips Solid State console stereo. I have mainly worked on tube guitar amps.
    I have very limited solid state experience. We cannot locate a schematic. Is there anyone here who can help us identify a few things? Ground scheme? Cap polarity etc? There are some real good folks here who have helped me a lot with guitar amps. I was wondering if a few of you are into other electronics as well.
    If this Hi-Fi stuff is not welcome here, do you have any recommendations for a good forum with helpful folks for us Newbies?
    Model is a Phillips R448. If there is some help here, and ok to post, I will start uploading photos and asking questions. Thanks, Keith
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,829
    Received: 769/4
    See if "Sams Photofact" has an issue for this model.
    4 names g1's Avatar
    Feb 2010
    10,330
    Received: 485/3
    Given: 1,060/2
    It's odd that there is so little showing up for this model, (using single L philips spelling).
    Is it a german unit? Any other model numbers on it? Post some pics?
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Thanks guys for checking in. No luck finding anything in Sams Photofact. It does appear that at least the guts were built in Germany. here are some pics. The final wood console may have been assembled in Canada.
    This is the turn table:
    Unsure where this is located:
    May 2011
    Out West, Canada
    172
    Given: 2/0
    May 2011
    Out West, Canada
    172
    Given: 2/0
    The radio works and plays. There is some crackling. Upon initial inspection we see some blistering caps. For starters I thought all e-caps should be replaced.
    First question:
    How can we identify polarity on these original 1968 e-caps? I believe they are Plessey brand.
    Another cap here. I am unsure of polarity. Black wire from cap node seen here does go to the chassis. I assume the chassis is ground. Does that seem logical? Power cord is two prong. No ground to wall it seems.
    New Member
    Jan 2018
    Wet Coast
    3
    Brother to keithb7 here...yes it is a German unit. The TT is a GC046 model ( I believe it is the same as a Grundig 46 series), and according to the original sales brochure the amp chassis is listed as model HC4. Not sure if the amp shares anything with Grundig components but so far I have not been able to track anything down online either.
    I did check "Sams Photofact" but no luck there. Thanks for any help you might have!
    G.
    30,829
    Received: 769/4
    Yours is a 448, but the one photo you posted shows the same chassis was used in the 458 and 468 models. A search for those two MIGHT turn something up.
    As to your can caps, the upper one has a single terminal and can tabs. Unless otherwise indicated, I assume the single terminal is the plus, and the can tabs negative. See the tiny square stamped into that single post on its base?
    Now look on the two legged cap. I see four diodes there making a bridge. The left terminal has the positive ends of the rectifiers. The right terminal has the negative ends of rectifiers. Note the left terminal has the tiny square stamped on it, while the right one has a tiny triangle.
    On both caps, look for a legend stating the cap rating. See if there is not a square and triangle printed on there, with one claiming positive. On the single leg one, see if ther is a + on the side.
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Ahh yes! I see the square an triangle now. Thank you.
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Does this pic help with further polarity clarity?
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Not much on the caps to ID polarity it seems:
  12. #12
    30,829
    Received: 769/4
    perhaps further around the can to the right, is ther any symbol after the rating?
    In general, I assume the can tabs are negative unless specified otherwise.
    In the case of the two leg one with no can tabs, I stick with my diode theory.
  13. #13
    4 names g1's Avatar
    Feb 2010
    10,330
    Received: 485/3
    Given: 1,060/2
    Enzo, what is up with the labelling on those diodes, seems backwards to me?
  14. #14
    4 names g1's Avatar
    Feb 2010
    10,330
    Received: 485/3
    Given: 1,060/2
    Quote Originally Posted by keithb7 View Post
    It's worth a try to check with justradios.
    They say 'antiques' but seem to have stuff right into the 70's :
    Canadian Antique Radios Schematics Diagrams Service - JustRadios
  15. #15
    May 2011
    Out West, Canada
    172
    Given: 2/0
    Twisted to reveal, further to the right:
  16. #16
    May 2011
    Out West, Canada
    172
    Given: 2/0
    My basic understanding is that the arrow points toward cathode (-) on the diode.
  17. #17
    30,829
    Received: 769/4
    To me the triangle (arrow) looks like an A, so ANODE, the bar is cathode. That is the flow of "conventional current", not electron flow.
    If I send AC into the anode, I expect positive DC on the cathode side.
    I expect the square symbol terminal on the two leg cap to be positive.
    I am just guessing, but from the photos, I think I am seeing this as a single supply power amp, the large two leg cap being for that. Then there are two smaller 1-leg can caps next to it, with the 0.5 ohm resistors. I see those as output speaker caps for the two channels. Anyone else get that impression?
    I cannot see it well, but it LOOKS to me like the bare wire lead from the positive leg of the 2-leg cap might go to a ground lug? Meaning this amp is running on a negative supply, like maybe PNP types, likely germanium?
  18. #18
    New Member
    Jan 2018
    Wet Coast
    3
    Your explanation of the 3 caps makes sense, the large for the power supply and the 2 smaller for the speaker channels. There is a fourth large cap as well but I believe it may be for the cassette portion of the unit.
    The bare wire is coming from a shielded lead, the inner wire of that lead runs to a circuit board. The black wire running from the same post as the bare wire runs to a chassis ground.
  19. #19
    New Member
    Jan 2018
    Wet Coast
    3
    Thanks for the lead, I will shoot them an e-mail.
  20. #20
    4 names g1's Avatar
    Feb 2010
    10,330
    Received: 485/3
    Given: 1,060/2
    Ok, I only thought the diode labelling appeared reversed because I expected a positive power supply.
    From the way the diodes are connected, yes, it must be a negative supply voltage at the triangle lug, with the square lug grounded.
  1. 2266c problem, looking for some guidance
    By jskeen in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-31-2015, 07:24 PM
  2. Bias Question - Rookie Needs Guidance
    By mikeboone in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-18-2008, 07:52 PM
  3. 5F11 - Need some guidance
    By Crawfish in forum Tweed Builders
    Last Post: 04-15-2008, 09:39 PM
  4. New and in need of guidance
    By mbutler in forum Theory & Design
    Last Post: 11-29-2007, 10:21 PM
  5. Need some guidance on an old Ampeg V3...
    By LJGriggs in forum Vintage Amps
    Last Post: 11-26-2007, 04:05 PM
