Results 1 to 5 of 5
Thread: What is this goop. High heat caulk?
    Jan 2014
    Chiraq
    835
    Received: 41/0
    Given: 60/1
    What is this goop that's occasionally seen ? It seems to be typically red and is some
    Sort of high heat, non conductive caulk? I'm
    Sure someone must know what it is called .
    Here is a funny picture from some rig. I also usually see this type of goop in sunn coliseum series to goop the big 10w emitter resistors to the chassis. Maybe it is for thermal coupling as well ?
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Quote Originally Posted by nsubulysses View Post
    That looks like old fashioned RTV Cement or Corona Dope, it was always that dark red color. An early version of technician caulk. RTV stands for Room Temperature Vulcanizing as in rubber.
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    What the heck is going on in there? Somebody has gooped in some rubber grommets to support the smaller heatsink?
    Quote Originally Posted by 52 Bill View Post
    I always thought those 2 were different things? The corona dope I'm used to is a brush on liquid that hardens, like a varnish. Maybe there are various types?
    Jan 2014
    Chiraq
    835
    Received: 41/0
    Given: 60/1
    That is the early version Sunn 1200S (the one made by fender in the 90s) that has a big floating heatsink supported by about 6 transistors only. So it vibrates and cracks the solder connections of the transistors. Fender later changed their Sunn 1200S to have a stabilizing bracket for the heatsink. The previous goop concoction is a picture of one I got in for repair where someone rigged a heat sink stabilizing bracket with high temp goop and some rubber grommets.
    Here is a pic of how fender changed the design
    original with floating heat sink
    and
    https://www.talkbass.com/attachments...b-jpg.1943449/
    I had a 1200S about 5 years ago and fender would not sell me the bracket since I'm not authorized service center, although they still offered it for free because I guess they basically considered it a bad design choice by them. I took it to an "authorized" shop my friend worked at and it was free to me and they paid the shop $35 to install the bracket. It was a 10 minute job.
    It seems like they now no longer offer this at all since the amp is pretty old. I think it was only made 94-99 or so. The first couple years with no stabilizing bracket
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    You're right the corona dope was a liquid, I was remembering some sort of putty that we used to use on the rubber high voltage plug to stop arcing.
    That bracket looks like it could be fabricated in about 10 minutes from alum. bar stock and a vise.
  1. Replies: 69
    Last Post: 03-05-2018, 05:33 AM
  2. MESA Express 5:25 - high b+, high current draw on power tubes - normal?
    By wagdog in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-24-2013, 10:05 AM
  3. Replies: 22
    Last Post: 06-10-2012, 06:12 PM
  4. removing tolex goop from wood
    By digthisbigcrux in forum Cabinetry
    Last Post: 06-08-2010, 05:06 PM
  5. marshall VS265 - high pitched noised at high volumes
    By littlered in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-23-2009, 11:10 PM
