Results 1 to 4 of 4
Thread: Wiring help
    New Member
    Jan 2018
    2
    Wiring help
    Iím building an interesting Strat style guitar and the guy Iím making it for is asking for something I havenít done before. Weíre putting an Invader in the Bridge position, a JB Junior in the middle, and a Hot Rails in the neck. He would like to have a Coil split pot on all three knobs in the same order as the pickups. Iíve wired a single split before but not all three. So 5 way switch, standard Strat knob arrangement and basically three humbuckers. Has anyone done this?
    May 2010
    Sioux Falls, SD
    5,318
    Received: 263/0
    Given: 230/0
    Welcome to the place!
    I would just use 3 push/pull pots- one for each pickup. Wire each coil split on each switch the same as you've done in the past when you did just one pickup.
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
    New Member
    Jan 2018
    2
    Thanks Dude! Thatís what I was thinking. I suppose I need to sit down and draw it out.
    4,503
    Received: 116/0
    Given: 77/0
    Before hardwiring the p-p switches I always recommend checking out how it sounds. On a strat you can run the cables under the pickguard, or remove a pot and run them there.
    One option to consider for other custom wiring jobs is a 4PDT mini-toggle switch which could do the series/parallel switching for 2 humbuckers. And with an ON/ON/ON switch you can do series/split/parallel switching.
    FWIW I think I've had better luck doing S/P switching on strat-sized humbuckers than full-sized ones...
    Good luck!
    Steve A.
  1. Replies: 5
    Last Post: 01-17-2017, 10:26 PM
  2. Series heater wiring, series/parallel heater wiring
    By diagrammatiks in forum Theory & Design
    Last Post: 05-11-2011, 01:14 PM
  3. I need help with old wiring.
    By htebreeder in forum Guitar Effects
    Last Post: 01-06-2011, 05:36 AM
  4. Need help with wiring...
    By mdelahoussaye in forum Music Electronics
    Last Post: 02-12-2010, 02:19 AM
  5. i really could use so help with h-h wiring
    By fenderman7787 in forum Guitar Tech
    Last Post: 09-16-2008, 04:54 AM
