Results 1 to 9 of 9
Thread: String dampening with .780" X .25" Alnico rods?
    Senior Member Chris Turner's Avatar
    Nov 2009
    Tucson, AZ
    240
    Has anyone else used .780" X .25" Alnico rods in their pickups?
    If so, did you notice any issues with string dampening (you know, when the mags pull too hard on the strings and you get that warbling effect)?
    Nov 2007
    Barnegat,NJ
    556
    Received: 9/0
    Quote Originally Posted by Chris Turner View Post
    Chris,
    This effect is more noticeable on the neck pickup because the string vibrates more toward the center of the string and a strong magnetic field will have more leverage in the neck position than in the bridge position.
    Here is an experiment you can do that will be very educational. Assuming that the string width at the neck position is 1.875 inches wide. Mount 7 0.25 inch diameter magnets such that each string is located in the middle space between magnets and the pull should be less but may also have a different harmonic structure as any horizontal movement will induce a voltage each time it passes the magnetic field side to side. This should emphasize a higher harmonic component.
    Tinkering is very educational and sometimes provides some unplanned results.
    I hope this helps.
    Joseph J. Rogowski
    Jun 2015
    253
    Received: 9/0
    I measured the Gauss at the top of SSL-4 pole pieces, the gauss reading ranged from 600G to 1000G depending on the pole piece. Allegedly they're AlNiCo 5, for which the standard sized pole pieces usually read right about 1050G. AlNiCo 2 poles usually read around 700G. The 1/4" pole pieces might be pulling harder due to their overall larger area of flux, but all in all I don't think it's substantially more or less pull that what you get from smaller sized pole pieces. I think the underlying reason why the 1/4" poles are not significantly stronger is because they're wider, but not taller, so they have a less efficient height to width ratio, with respect to the coercivity AlNiCo 5.
    796
    Received: 2/0
    I have several Tele bridge models that use .800" x .250" A5 rods (and A3), but no neck pickup models of any kind with the big rods. At the bridge there will be far fewer string-pull problems and so I haven't run into any during testing. The neck would be more vulnerable to this but I'm open to big rods for neck depending on customer needs/requests.
    Nov 2009
    Tucson, AZ
    240
    Quote Originally Posted by Zhangliqun View Post
    Do you have a source you can share for those .250" X .800" A5 and A3 rods?
    CNC Trial by Fire kayakerca's Avatar
    Jul 2011
    Ottawa, CANADA
    759
    Given: 6/0
    T posted a price list a while back from Magnetic Hold that has both A3 and A5 in size .250" X .800".
    http://music-electronics-forum.com/t5313/#post370731
    Take Care,
    Jim. . .
    ____________________________________________________
    In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    971
    Received: 6/3
    I don't think you'll have any problems with string pull with A3 or even A2 .250" rods in the neck position, Dave. Although I too think they're much more useful in the bridge position.
    Pepe aka Lt. Kojak
    Milano, Italy
    796
    Received: 2/0
    Quote Originally Posted by kayakerca View Post
    They'll make Alnico 2's in that size also. They'll make Alnico rods and bars in almost any dimensions -- I've had them make me some A5's that are .250" x .900".
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,297
    Received: 199/21
    Given: 197/9
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
  1. Replies: 1
    Last Post: 05-05-2016, 07:29 AM
  2. Looking for .25"x.25"x2.38" magnets
    By LowNote in forum Pickup Makers
    Last Post: 10-10-2015, 07:52 PM
  3. Mesa 5:25 "ghost note"
    By Danglin' Fury in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-29-2011, 01:49 AM
  4. 1/4" x 3/4" alnico rods for P-bass pickup
    By GlennW in forum Pickup Makers
    Last Post: 02-03-2007, 03:52 AM
