Results 1 to 35 of 35
Thread: Bugera 1960 half volume?
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    So I have this Bugera 1960 on the bench... When I first turned it on, it was loud as hell... I was scratching my head as to what the problem was... So I turned the amp off, then back on... BAM! it was half the volume... I turned it back off then on again, half volume... So I let it sit for a day... Came back and turned it on again and had full volume... Put the standby on, then switched the standby off and I had half volume.... It came in originally with a blown mains fuse and a bad tube... I replaced all 4 tubes with a matched quad and I've had zero problems with the power tubes... They all are on and have that nice blue glow inside... I have replaced the choke with a resistor, same thing... Full volume than half after I cycle the standby switch... Put the choke back in, same thing.... Replaced all preamp tubes with know good tubes.... Same problem.... Does it sound like maybe a cap? Coupling or otherwise? Maybe something in the phase invertor? Any replies would be most appreciated.... Thanks for looking...
    Lest We Forget g1's Avatar
    Feb 2010
    10,415
    Received: 582/21
    Given: 1,286/5
    Is it the infinium or not?
    Have you tried it with a patch cord connecting the FX send to FX return?
    Oct 2015
    NEPA
    618
    Received: 66/1
    Given: 54/0
    I'd check all the solder joints on the tube sockets and elsewhere. If you bang on the amp while the problem is there, does it fix it?
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    It is not the infinium... I have tried jumping the effects loop... I have not tried banging it... I looked with a magnifier to find cold and cracked solder joints, to no avail... I just soldered every tube socket pin and will try it when I can... I'm at my day job atm....
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,934
    Received: 887/5
    SO when it is half volume, plug the guitar into the FX return. Still half?
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Guitar plugged into effects return = half volume as well...
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Playing the Ohm Ranger I took a couple of measurements Power on, and standby in the play position...Power tubes... Heaters 24.7 volts DC, plate 457 Volts DC, screen grid 451 Volts DC, control grid ~-40 Volts dc...
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Also, when I move the standby in to play position, it seems the signal sort of swells into being... My Bugera 333xl, as soon as the standby switch is moved, I have sound... This 1960, like I said, takes approximately 3 seconds for the sound to be there...
    Feb 2010
    10,415
    Received: 582/21
    Given: 1,286/5
    Have you checked voltages on the PI tube?
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Not yet... I will this evening... This week has been a crazy one...
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Checking the voltages on the PI...
    Pin 7 has ~22 VDC pin 2 has 21.07 VDC,
    Pin 1 and pin 6 have 203 and 224 VDC respectively, pins 8 and 3 have 34 VDC on them... And pin 4 has -18.2 VDC and pin 5 has -6.46 VDC... Measurements respect to ground...
  12. #12
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Anybody? Lol
  13. #13
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Soooooo.... I just measured my output transformer primaries... Red (center tap) to brown: 6.5 Ohms... Center to blue:5.4 Ohms... Measured with tubes in....
  14. #14
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    With the power tubes out, 7 and 8 ohms on the primary... From brown to blue it reads about 11 ohms...
  15. #15
    Dec 2009
    Devon, UK
    3,007
    Received: 281/1
    Given: 265/1
    Whilst in half power fault mode, I would do some basic tests like check the bias current in each tube just see see if they are all making connection. Then I would check that each output tube grid is being driven - use a 1KHz sine wave signal generator on the input (or FX return), dummy load and scope or DVM on ACV with a 10nF 600V cap in series with one of the leads.
  16. #16
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    I haven't been able to get it in the full volume mode at all lately... Just half volume... All the tone controls seem to work... It is quiet... Just half volume...
  17. #17
    Dec 2009
    Devon, UK
    3,007
    Received: 281/1
    Given: 265/1
    Quote Originally Posted by Danglin' Fury View Post
    That's good then. Have you ever tried to fix something that won't go wrong? Frustrating doesn't come close...
  18. #18
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Yes sir I have... Lol! And you are correct... Frustrating doesn't touch it... Lol!
  19. #19
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    I have access to the 2 22nF coupling caps that are in the phase invertor... I'm going to change those tomorrow and see if that fixes the problem... The effects loop board seems to be ok... The jacks as well... When the amp came to me, the customer said the mains fuse blew and there was a dead power tube... I measured everything on the power board and it is ok.... As the power tubes are all operating as advertised...
  20. #20
    30,934
    Received: 887/5
    Find those two caps on the board. Apply a steady signal to the amp. Now see if the signal is present on the phase inverter side of those caps, and then see if it is present on the power tube side of those caps. That will tell you if the caps are diminishing the signal
    I don't know what operating as advertised means. All glowing heaters? Did you check for B+ on the screen of every power tube? Pin 4.
  21. #21
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Yes sir... ~450 Volts DC on pin 4 of the power tubes....
  22. #22
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Anything? Also earlier in the thread, I took some measurements of the output transformer... The primaries look a bottle low to me, anyone else?
  23. #23
    Dec 2009
    Devon, UK
    3,007
    Received: 281/1
    Given: 265/1
    DC resistances don't tell you much. The best methods are probably (a) measure the primary inductance or (b) ring the transformer see RG Keen's method.
    Have you measured the grid drive yet?
  24. #24
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    I will do the lightbulb test, although its proving difficult to find a neon bulb locally... Here's the deal... I work at an electronics shop repairing and modifying high end analytical equipment for the battery test industry... Between that and my sons visiting every other day I have very limited time to work on amps, although I love doing it... Someday I hope to own my own shop but I digress... I just found out the shop I work in has a signal generator so tomorrow I'm gonna put in a 1kHz sine and see where the signal gets small... Man I'm telling you... The voltages in this amp and the resistance readings are all good... I've measured the resistance on all the caps (R.G. Keen says below 15 k ohms = bad caps) all readings are well above that...
  25. #25
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Ok... Just applied a 1kHz sine wave into the Bugera.. Aaaaaaand it started red plating... Now its half volume AND the power tubes are red plating... Anything? Anyone?
  26. #26
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Aaaaaaaand with the output transformer in the amp, still connected, I have about 237K ohms resistance between all taps of the primary measured to the secondary taps....
  27. #27
    Feb 2010
    10,415
    Received: 582/21
    Given: 1,286/5
    Does the red-plating only happen with signal?
    Do you have any other type of OT you can sub in there to test?
  28. #28
    Senior Member TimmyP1955's Avatar
    Mar 2007
    Indianapolis
    354
    Received: 5/0
    Given: 2/0
    Disconnect the negative feedback lead before measuring.
  29. #29
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    The red plating most definitely only happens with a signal present... I may have a friend that has a spare OT he can loan me... Im gonna see if the bias caps are leaking today around 11:00-11:30... So I Will be able to eliminate that... Perhaps I can get another OT this evening... If it is the OT, any place I can find one for under $125?
  30. #30
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    And thank you sir... I completely forgot to do that...
  31. #31
    Supporting Member
    Oct 2011
    Manchester, UK
    325
    Received: 13/0
    Given: 5/0
    Not a terribly helpful reply, but my friend gave me a non-infinium 1960 that had bounced between all the techs in the northwest, who declared the amp had no fault, despite producing nearly no power and redplating the tubes. I had a poke around and all the voltages seemed sensible. I was going to test the OT with a neon but I instead have opted to pull all the PCBs out and build something else in it with a spare OT I have.
  32. #32
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    So did you try the other transformer to see if that was it?
  33. #33
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    Removed the feedback wire... Still have
    ~237k ohms between the primary and secondary...
  34. #34
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    It was the output transformer... Got one from eBay for $40... Worked perfectly... After reading several posts with extremely similar faults, and after troubleshooting everything else and finding no fault I deduced that it to be the output transformer...
  35. #35
    Jul 2008
    Tulsa, Ok.
    191
    Received: 1/0
    I also want to thank each and every one of you that helped me.... All of the knowledge here is worth so much... I appreciate all of you...
  1. Low volume and red plating (bugera 1960)
    By Zozobra in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-24-2016, 01:59 PM
  2. Bugera 1960 Bad Distortion When I Play Hard
    By Just Mike in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-08-2014, 09:59 PM
  3. Bugera 1960 infinium Schematic
    By harrisxr650 in forum Mods & Tweaks
    Last Post: 04-28-2014, 09:06 PM
  4. Bugera 1960 Swap out 5881s for 6L6GC Tubes - Necessary Mods?
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-28-2013, 03:13 AM
  5. BUGERA 1960 schematic for PPIMV
    By armaddy63 in forum Schematic Requests
    Last Post: 08-29-2012, 05:01 AM
