Results 1 to 7 of 7
Thread: 9 pin socket base with metal centre
    Jun 2017
    England
    102
    I've just noticed that the 9 pin base I've received has a metal centre with a tab on it and as I'm going to be using a 12ax7 tube that has no pin in the centre should I leave the centre tab unconnected or does it need to be connected to something or do i need to order a socket without the shield ??
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,934
    Received: 887/5
    Ignore it, or use it as a tie point for components.
    The center terminal used to be a lot more common than it is today. I might guess because in RF circuits like TV sets and radios, keeping component leads short mattered more than in guitar amps.
    Jun 2017
    England
    102
    Thanks enzo
    Jul 2011
    Adelaide, South Oz
    695
    Received: 20/0
    Connect it to 0V and use it as the local star ground point. Thats what I do with these type of sockets.
    Cheers,
    Ian
    Jun 2017
    England
    102
    Good idea thanks
    Scott
    Cheshire, UK
    1,903
    Received: 190/3
    Given: 125/0
    On EL84 amps I fit the grid stopper between the centre pin and grid pin as the 'unused' pins on an EL84 are all internal connections.
    Supporting Member
    Staffordshire UK
    3,467
    Received: 143/0
    Given: 211/1
    They can make it awkward to wire heaters in accordance with Merlin’s guidance. Cutting the terminal off leaves sharp edges that might damage the insulation of wire passing over it (probably not a big deal).
    With ceramic sockets the post is part of a crimped fastener that holds the socket assembly together, so it can’t be removed, in the way that the centre posts of plastic sockets can. Don’t ask me how I discovered this.
  1. Where can I get this 8 pin socket + connector
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-01-2012, 06:56 AM
  2. Broken Octal Tube Socket Pin ?? HELP !!
    By crunchman in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-21-2012, 03:00 PM
  3. does a non metal base plate need shielding?
    By copperheadroads in forum Pickup Makers
    Last Post: 05-22-2010, 05:45 PM
  4. Need advice on installing an 8 pin IC Socket
    By ENB in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-30-2008, 09:48 PM
