Results 1 to 2 of 2
Thread: AVO MKIV Tube Tester Meter Rebuild?
    Member parentheticalfact's Avatar
    Mar 2007
    United States, Portland Oregon
    85
    Given: 4/0
    Question AVO MKIV Tube Tester Meter Rebuild?
    Greetings!
    I have a lovely AVO MKIV tube tester. Someone has disassembled the meter and the pole-piece is dislodged. The coil still reads good and I fear handling it as it could be completely destroyed in short order in it's current condition.
    JAC will service these and restore them but I have to send it to Europe to see if it can be saved. Is there in anyone in the United States who knows how to properly service this meter? It is high precision meter of an odd impedance and I would only like to substitute it if absolutely necessary.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,934
    Received: 887/5
    It is the physical meter, so an instrument repair company need not know anything about the tube tester specifically. Look up "test instrument repair and see if anyone local pops up. COmpanies that repair and maintain electronic test gear for engineer anda labs could probably repair a meter movement. There are national companies in the USA doing this too.
  1. On the look out for a tube tester!!
    By DrGonz78 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-12-2014, 12:13 AM
  2. Avo valve tester questions.
    By bassetrox in forum Tubes (Valves)
    Last Post: 03-10-2013, 06:49 PM
  3. BK 700 tube tester meter not working
    By Markorock37 in forum Music Electronics
    Last Post: 08-04-2012, 05:31 PM
  4. Bought a tube tester and need 9 pin adapter for octal tube socket
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-02-2012, 05:34 AM
  5. ESR Meter / Tester
    By Phostenix in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-08-2009, 09:05 PM
