Results 1 to 5 of 5
Thread: How to check a relay on a Fender Amp
    Aug 2013
    98
    Received: 11/0
    Hi guys.
    I have a Fender Prosonic amp with a noise issue on the clean channel, according to the analysis made, the problem is located on the first relay. Is there a way of checking this kind of components with a mutlimeter?
    Any help would be appreciated.
    All the best.
    CE
    Dec 2009
    Devon, UK
    3,008
    Received: 281/1
    Given: 267/1
    Relays seldom made a noise in and of themselves so it would not be the first place I'd be looking. What kind of noise? What analysis exactly? If a pop it might be DC where it shouldn't be. If a hiss you may have a bad component.
    The relay can best be tested out of circuit using a power supply to operate the coil and using the continuity range on the meter to check the contacts. This will tell you if the contacts are working and low resistance.
    PS: I just found your other thread. This only happens on the clean channel. I'd suspect C3 i.e. the cap that feeds the clean volume pot.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,857
    Received: 916/5
    Given: 943/0
    Quote Originally Posted by nickb View Post
    C3 and the clean volume pot would be the only component exclusive to the clean "channel". So there's that. But it's indicated that the problem manifests at the same volume regardless of volume pot setting. So that would put it ahead of the volume pot, wouldn't it?
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Dec 2009
    Devon, UK
    3,008
    Received: 281/1
    Given: 267/1
    That's new info to me. I guess it's in the other thread? A pity they got split if there was important info in there. If true then I would tend to agree. At a bit of a stretch it could be a bad ground on the pot, I suppose. The only way I can think of to reliably test a relay for noise would be the replace it.
    Lest We Forget g1's Avatar
    Feb 2010
    10,416
    Received: 583/21
    Given: 1,290/5
    You can hardwire across the appropriate pins to bypass the relay. If the problem disappears, you know the noise was from the relay. If you still hear it, the problem is elsewhere.
  1. Rule #1 in guitar amp repair - Check the obvious!
    By Axtman in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-29-2018, 01:24 AM
  2. Relay
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2017, 05:00 AM
  3. Implementing a relay in a hand-wired amp
    By hamfist in forum Mods & Tweaks
    Last Post: 12-20-2008, 06:09 PM
