Can anyone explain how to adjust overall height on these?
Fender tech tonic bridge
Vote like your future depends on it.
Originally posted by dmartn149 View Post[ATTACH=CONFIG]46870[/ATTACH]Pretty rare bridge/guitar I've never seen one, but ignorance won't stop me from offering advice I'd try slacking off the strings, loosen the allen screw in the center of the posts and turn the post in or out to adjust. Be careful, don't use excessive force as these instructions may be all wrong
Strange design, not intuitive at all. Needed to lower the bridge to get action right, found that after taking out the center allen screws the slotted head comes off and there is a hex fitting inside. Unfortunately the bridge was already bottomed out, so I had to use the micro tilt on the neck to get the action in.
Does the under side of the slotted head have a hex shape that engages the hex on the post? My thinking was that you should crack the allen screw (not take it out) to unlock the post then turn the slotted part.Vote like your future depends on it.
Originally posted by dmartn149 View PostDoes the under side of the slotted head have a hex shape that engages the hex on the post? My thinking was that you should crack the allen screw (not take it out) to unlock the post then turn the slotted part.
Originally posted by dmartn149 View PostGood. what ever works. Those are really cool looking guitars IMO, both the single and double pickup models. I really like the feel of a wrap around bridge too.
