My OT has a 4 and 8 ohm tap. I want to hook up two jacks, one for each, so that I have a choice of plugging into either cabinet. The problem that I see is the feedback connection goes to the positive terminal on the output jack. If i connect to both I will essentially be shorting out the 4 and 8 ohm taps. My thought is putting in a 2 way switch that will send the feedback connection to either the 4 or 8 ohm jack, whichever is being used. Is this the best solution?
5f2a head First Build. Hooking up dual 4 and 8 ohm outputs
Don't make it more complex than it needs to be. The feedback is designed for the circuit as is. The voltage of the one tap. It doesn't matter if you use a different tap for the speaker.
SO wire the thing up stock, then all you need do is mount a second jack, and wire it to the unused tap on the transformer.Education is what you're left with after you have forgotten what you have learned.
Originally posted by gymrat1964 View PostMy OT has a 4 and 8 ohm tap. I want to hook up two jacks, one for each, so that I have a choice of plugging into either cabinet. The problem that I see is the feedback connection goes to the positive terminal on the output jack. If i connect to both I will essentially be shorting out the 4 and 8 ohm taps. My thought is putting in a 2 way switch that will send the feedback connection to either the 4 or 8 ohm jack, whichever is being used. Is this the best solution?
Edit: Simulpost with Enzo
And I'll back Enzo and Tom. The feedback loop connects to only one secondary. If there IS only one secondary then it can be connected to the output jack. This was the case with the 5f2a. Since your amp will have impedance choices you'll want to connect the feedback loop to a single impedance tap instead of the output jack. This is because the feedback loop needs to supply a fixed voltage to a circuit, prior to the output tube and speaker relationship, that operates at a fixed voltage regardless of speaker impedance."Take two placebos, works twice as well." Enzo
Originally posted by Dave H View PostBut you could plug a 16 ohm cabinet into the 8 ohm jack AND a 8 ohm cabinet into the 4 ohm jack"Take two placebos, works twice as well." Enzo
Any way you print it on the amp, there will always be a large percentage of the amp users who don't get it.
We print "two jacks wired in parallel", and think it explains something. But to them it does not.
I think the average user sees an ohms number and goes no further. "Oh, two jacks that say 4 ohms, I guess I can plug two 4 ohm speakers into the amp then."Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI think the average user sees an ohms number and goes no further. "Oh, two jacks that say 4 ohms, I guess I can plug two 4 ohm speakers into the amp then.""Take two placebos, works twice as well." Enzo
On the other hand, one more thing to fail...
We do have people write in asking if their speaker says 4/16 ohms and their amp says 4/8/16, should they set it to 4 and run two cables?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOn the other hand, one more thing to fail...
We do have people write in asking if their speaker says 4/16 ohms and their amp says 4/8/16, should they set it to 4 and run two cables?The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
