In my quest for understanding how the tube amp works I have coloured the layout drawing for my build have I done it right ? Also it got me thinking about the negative feedback circuit am I right in thinking that a portion of the output signal gets fed back to the second cathode of the preamp tube and would i be correct that this would only be active in the circuit if the 4 ohm output was being used as it isnt connected to the 8 ohm output ? If it is active in both outputs wouldn't the amount being fed back differ depending on which output was being used?
How it works
How it works
In my quest for understanding how the tube amp works I have coloured the layout drawing for my build have I done it right ? Also it got me thinking about the negative feedback circuit am I right in thinking that a portion of the output signal gets fed back to the second cathode of the preamp tube and would i be correct that this would only be active in the circuit if the 4 ohm output was being used as it isnt connected to the 8 ohm output ? If it is active in both outputs wouldn't the amount being fed back differ depending on which output was being used?Tags: None
No, you have not done it right. Don't mean to be rude but no one thinks about layout drawings like that. If you can not read schematics it is a must for any kind of analysis. Try this:
https://robrobinette.com/Reading_Tub...Schematics.htm
The feedback is active no matter which output you use, and the voltage at the 4 ohm tap stays the same no matter which output you are using.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Ha yeah just checked out the link (and bookmarked it!!) Think I'm in for a few late nights digesting that but obviously essential can't help but wonder if you gave two amp builders a circuit schematic that they had both never seen before and got them to build an amp from it how different (or similar) the amps would be ? And therein lies the art I guess!! Thanks though given me a lot to think about
Originally posted by Jarvini View PostHa yeah just checked out the link (and bookmarked it!!) Think I'm in for a few late nights digesting that but obviously essential can't help but wonder if you gave two amp builders a circuit schematic that they had both never seen before and got them to build an amp from it how different (or similar) the amps would be ? And therein lies the art I guess!! Thanks though given me a lot to think about
Builder in that case only mounts and solders, assuming both are competent .Juan Manuel Fahey
I meant if they just had the schematic and nothing else no idea of a finished design so they worked from scratch picked their own blank chassis their own components, wire, circuit board layout , valves , grounding scheme, wire dress, surely they wouldn't build exactly identical amps
Originally posted by Jarvini View PostHa yeah just checked out the link (and bookmarked it!!) Think I'm in for a few late nights digesting that but obviously essential can't help but wonder if you gave two amp builders a circuit schematic that they had both never seen before and got them to build an amp from it how different (or similar) the amps would be ? And therein lies the art I guess!! Thanks though given me a lot to think aboutOriginally posted by Jarvini View PostI meant if they just had the schematic and nothing else no idea of a finished design so they worked from scratch picked their own blank chassis their own components, wire, circuit board layout , valves , grounding scheme, wire dress, surely they wouldn't build exactly identical amps
So for the sake of argument, discard amp building as art. When a civil engineer builds a bridge, every choice they make is based on the charts, graphs, and tables that provide data about the materials chosen. The engineer cannot willfully disregard those constraints. There are similar constraints in amp building. As long as the constraints are understood and obeyed, the amp functions properly. And as two bridges that are built with exactly the same specs and materials will look pretty similar (form follows function!), two amps built to the same schematic with the same parts will end up pretty close.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Jarvini View PostYeah point taken!!! be an interesting experiment though just to hear them but then two amps built with exactly the same components would probably sound different anyway due to tolerances so maybe not!!
It is interesting to note that if you give the same identical amplifier to a group guitar players and you tell them that one of the amplifiers has a specially selected type of capacitors (even though it does not) then a high percentage of players would probably pick the "special" amplifier as the better sounding one.
Edit: Think of a schematic as the language of electronics. Once you learn how to read and create schematics you can understand and convey electronic information very efficiently. Without the schematic you are in a position similar to writing a thousand words to convey what can easily be understood by a simple picture.Last edited by Tom Phillips; 02-10-2018, 08:30 PM.
I think you are all misunderstanding what I first meant!! I didn't mean that two different amp builders would interpret the circuit differently and build a different circuit than each other!! I meant what size chassis they would use what brand of capacitors what type of resistors valve placement transformer choice wire choice solid core or braided star ground bus ground steel or aluminium chassis eyelet board or turret board !! A circuit schematic wouldn't specify anything other than values,tolerances and voltages all the electronic information surely the two amps would be made of completely different brand and type components thus producing 2 different sounding amps that apart from both following the same electronic blueprint would in effect be different
Originally posted by Jarvini View PostI think you are all misunderstanding what I first meant!! I didn't mean that two different amp builders would interpret the circuit differently and build a different circuit than each other!!
What you are talking about boils down to something like "a Fender Tweed Bassman built by my Cousin Joe, who already built 40 amplifiers, sounds better/worse/brighter/darker/cleaner/dirtier/different than one built at Fender Factory in 1960, even if they use same value components as specified in schematic".
Well they will sound amazingly similar, and hard to pick in blind testing.
Any possible difference may be due to component tolerance, but that may work for/against any of them, old or new, and in any case does not depend on "builderīs hand" as you are trying to imply.
You keep talking about "Art" ,And therein lies the art I guess!!
It does not work that way.
Now you are trying to twist its meaning by adding new parameters, but in any case they are not significant as you think.
We are talking differences in sound, which is what matters.
Letīs see the new variables you added, one by one, wondering about whether they affect sound/tone significantly (meaning they can be pickwed in a blind test) or not:
I meant what size chassis they would usewhat brand of capacitors
If you said *type* then you might have had a point, but you said *brand* , so ....
Old style carbon comp may hiss more, that wonīt change *sound* and I fail to see extra hiss as a "feature".
valve placementtransformer choice
You may use a way undersized or underspecīd one but that woukld not be "competent".
Now using standard commercial ones such as original Fender (yes, you can buy them for your own builds and price is very reasonable) to Classic Tone to Heyboer to Hammond to (gasp) 3X as expensive Mercury Magnetics, and all others in same class, commercially available, they all sound about the same, Manufacturerīs sugarcoating notwhitstanding.
Canīt imagine anybody crazy enough to use a Japanese handmade $3000 Audio Note silver wire wound transformer
but even so I guess heīd be dissappointed at the abismally small difference, if any at all.
ground bus ground
Thereīs many ways to skin a cat, all yield a nice warm overcoat as end result.
steel or aluminium chassiseyelet board or turret board !!
No audible difference, at all.
Iīd even include well designed PCBs, howīs that?A circuit schematic wouldn't specify anything other than values,tolerances and voltages
all the electronic information surely the two amps would be made of completely different brand and type components thus producing 2 different sounding ampsthat apart from both following the same electronic blueprint would in effect be different
I guess (maybe wrong) that you have been over reading what many "Boutique" builders claim.
Now getting to the point:
Sad truth is that since Tube amps are electrically simpler than SS, their technology is well "mature" by now (thatīs the understatement of the year, we are still using 60/60 year old schematics, based on 70 year old datasheets) , parts are more error-tolerant (you can see plates get red hot, and turn amp OFF, Silicon junctions die in milli-seconds with no warning) and somebody with no formal training at all can still build a working amp just by following colourful layouts , where even resistor color bands are indicated, all this has resulted in hundreds if not thousands people building and most hopefully trying to sell their products ...... and for a good price I might add.
2 big problems:
1) they are all building the exact same 10 or 20 (if that many) Classic circuits.
FWIW in another Forum there is a thread called "How many 5E3 clones does the World need?"
2) they have to justify a high price or numbers simply do not add up.
Fender offers **excellent** and versatile 40/60W Tube amps in various configurations, for about U$1000 , 40W Blues Junior for U$700.
Other makers (think Bugera/Behringer) offer excellent ones for U$400 or less.
Then Boutique builders have to justify charging U$2000/3000 or more for , say, 15W amps (although power out is not the main factor here) so they HEAVILY insist on , for us, irrelevant details.
Irrelevant meaning they donīt cange *sound* , although might be "nice to have", or "nice to look at".
FWIW I started studying Engineering in 1969, by '71 or '72 was quite advanced, and it being Industrial Engineering, the only branch which specifically cares about the Economy/Management side of things (others focus more on the specifically Technical area of esah specialty) we had Marketing courses.
One typical assignment/"homework" was splitting us in 5/6 guy/gal teams, each of us was given a 1 pint of generic (unscented of course, no additives at all) Industrial type Detergent (Lauryl Sulfate something) , as plain vanilla and unexciting product as can be, and assignment was to come back in 1 week or 2 with a Publicity campaign designed to make Customers buy "my product instead of others" , pay significantly more than what Market would dictate, and at the same time feel proud and happy about doing so.
Let me tell you that BS was not only not forbidden, but actively promoted !!!!!
Talk about used car/snake oil salesmen !!!!!!
So this Boutique insistence on really irrelevant details makes a lot of sense to me.Juan Manuel Fahey
You can use carbon composition, carbon film, or metal film resistors and they all will sound alike. One might be a little nosier than the other, but that isn't tone.
Parts tolerances affect even factory amps. Those old 5E3 Fenders were made with 20% resistors, caps had even wider tolerances. The schematic says right on it, all voltages within +/-20% That means in any given amp the 100k plate resistor on the input stage could be 80k to 120k and be in spec. Your 400v B+ could be 320v to 480v. usually not that wide, but sure enough, line up a few 5E3 amps when new, and they sounded different. They all sounded like 5E3s, but you could hear a difference.
Different speakers sound different, but you proposed the same parts list.Education is what you're left with after you have forgotten what you have learned.
I apologise if I have offended anyone with my questions I am merely trying to understand in my own way the how valve amplifiers work and are built as I am building one for myself and I want to do it the best I can
I unfortunately have not had the years of bench experience that many on here have and no doubt never will have so I have to go about it a different way using books, forums, information from the net enlarging pictures so I can see how its wired etc.
I am not building my amp so I can open it up every time someone comes round to show them the how its wired and expect them to gasp in awe at the components I have selected, nor am I building it to sell it for an extortionate price I am building it to play it and as such I want it to be built as good as I can possibly build it knowing that I have used the best parts I could afford and using the knowledge I am slowly gaining wired it internally the same way an experienced builder would have done I could easily source a load of cheap Chinese parts and throw it together cross my fingers and hope it sound ok but that's not the way I do things.
If I were to build a car I would do the same using chromed and anodised engine bay parts genuine body panels decent tyres trick interior the works would that make it a better car probably not but it would be my car and I would know that every nut and bolt whether you can see it or not was the best it could be and on the flip side of that I could build a car using the cheapest pattern parts old rusty nuts worn out interior etc. would it still be a car yes, would it get me from a to b like the trick one yes but I would know that its probably going to fail in the future and I would probably be spending most of my weekends wishing I spent the bit extra when I am stuck out there with my head under the bonnet fixing the cheap part that's gone wrong again.
I realise that a lot of what you read is marketing mumbo jumbo and used in an attempt to justify the savage prices that the boutique builders charge but things are only worth what people will pay for them I myself would not spend that sort of money when it could be built for a fraction of the price but you need to be that way inclined and do some research and do it properly I know people that cannot wire a three pin plug and because of that they would call an electrician to do it for them and im sure he would charge a fortune for it but whos in the wrong ?
I'm also pretty sure that the people that spend 10 to 20 grand on an original fender amp are never going to play them and they would probably be awful or go pop anyway if you did unless you are someone like Joe Bonnamassa who no doubt has an amp tech to check and repair them first but in doing so you don't have the original anymore anyway so whats the point?
An amplifier is just that an amplifier it amplifies what you put into it so a lot of the so called tone comes before it, if you gave Jimi Hendrix a 5 dollar amp I'm pretty sure he could make it rock and still have the Hendrix sound and if you gave a novice a 5 grand boutique amp they would no doubt sound awful.
If an experienced amp tech was to knock on my door and say "hey do you want a job i'll teach you everything I have learned over the years you can use my workshop and all my equipment while your learning" then I'd be there the same day but it isn't going to happen so I've got to do it my way as im sure many of you did and that involves asking dumb questions, research, debating on forums etc.
So just to reiterate I'm not trying to annoy anyone I'm just trying to build the best amp that I can for my own pleasure with the peace of mind knowing I've done it correctly and safely with parts and products that are tried and tested surely that's where the fun in all this is?
we all have to start somewhere and I'm a long way back from most of you on here but you were here once too!!
But I would like to say thankyou for all the help that I have received so far and I am slowly getting there one dumb question at a time
scott
No one is offended , Scott. We do want to help. We don't know you very well, so we have to approach the questions with that in mind.
Think about building that car. You probably wouldn't buy 10 cent Chinese spark plugs on ebay, but would you worry whether the car would be better with Mercedes plugs or BMW plugs, and would either of those be better than Bosch plugs from the store? Maybe a better question would be what would you tell a guy starting into car building if he asked you that?
I don't know that you are doing it, but we worry about people getting carried away with the tiny details that ultimately don't matter. Like the car: should I take the tire inflator caps off to lighten the tires? In my amp, are Allen Bradley pots better than Ohmite? Beats me, both are excellent. And the plain old CTS pots Fender used are working still on 60 year old amps, and they cost a lot less than my ABs and Ohmites.Education is what you're left with after you have forgotten what you have learned.
