Marshall Artist 3203 new PT buzz
  • Marshall Artist 3203 new PT buzz
    So, got a Marshall Artist 3203 with a fried power transformer.
    All secondary windings shorted, but not to each other.
    Ordered a replacement from Mojo, everything works as it should but the PT has a typical buzz even with the secondaries disconnected and the buzz is even heard from a speaker even with no tubes in, standby on, and even when I disconnected all the secondaries.
    It was getting warm when connected and running fine, which caused me some alarm.
    Nothing is drawing more current than normal, I checked all the secondary connections, filament draw normal, HV draw normal.
    No spec for the LV winding but it's not drawing much current either.
    What is a bit odd is the -15v rail measures like 1M to ground while the +15v rail is only 2K ohms.
    But that is still only 7.5ma.
    I replaced the LV filter caps just to make sure.
    So am I being paranoid about the PT being warm and WTF can I do about the physical buzz?
    Maybe try some better mounting/insulators or plastic washers.
    Relevant technical info:
    Well, if I rotate the trans 45' clockwise the hum disappears.
    Of course it can't be mounted that way.
    I'm guessing it's due to the OT only a few inches away.
    All this chassis room and they had to put the tranny's next to each other.
      I wonder.....
      The trans came with the screws pointing up, like if it was to be mounted inside the amp.
      Maybe I'll try that.
        Stupid me, not enough room to mount it inside.
        Think reversing the primary leads would have any effect?
        Grasping at straws here.
        Time for a drink.
          Is it possible to rotate the OT instead?
            Possibly, everything is possible with enough time and power tools.
            It might actually be easier to rotate the PT to the aforementioned 45' where it is quiet.
            Mount it up about 1/4" on standoffs and drill 4 new holes.
