Results 1 to 6 of 6
Thread: Heater wiring question
    Jun 2017
    England
    102
    Is there any reason I shouldn't use this cable for wiring my heater filaments it is 1mm solid core copper 300/500v rating and the spec sheet says 11 amps max current the temp rating is 70 degrees I've only got two tubes to run it to and the last tube (12ax7) would only need 1 wire in each pin so space no problem would the 70 degrees be a problem I'm building the amp so the tubes are on top not underneath so heat should be less?
    Whenever I suggest components I'm always told that I should use more basic stuff and not be fooled by the mojo or am I wrong?
    Supporting Member
    Staffordshire UK
    3,428
    Received: 88/0
    Given: 84/0
    70C is fine, well above the operating temp your amp could reach, but I hate wire with flimsy insulation that melts / deforms by solder points.
    So I suggest to check that it solders up ok before you commit to it.
    Oct 2015
    NEPA
    582
    Received: 48/1
    Given: 40/0
    If all your tubes are in parallel, that piece won't work, unless you retwist it properly.
    Jun 2017
    England
    102
    Don't worry only one power tube and one preamp tube and I only twisted that piece to give an example of the wire I was talking about
    Jun 2017
    England
    102
    I also laid it on graph paper so you could see the size
    Jun 2017
    England
    102
    Plus I've spent most evenings reading Rob robinettes forum and I thought series and parallel heater wiring only mattered with push pull type amps or am I wrong?
  1. Correct heater wiring ?
    By copperheadroads in forum Build Your Amp
    Last Post: 03-18-2017, 03:25 PM
  2. Wiring Heater String...
    By Bob M. in forum Build Your Amp
    Last Post: 09-26-2014, 12:34 PM
  3. Series heater wiring, series/parallel heater wiring
    By diagrammatiks in forum Theory & Design
    Last Post: 05-11-2011, 01:14 PM
  4. Vibro Champ Heater Wiring
    By trem in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-17-2010, 05:45 AM
  5. Question about heater wiring in a Champ build
    By Regis in forum Theory & Design
    Last Post: 02-28-2007, 01:47 AM
