Results 1 to 9 of 9
Thread: A Fender pickup pole piece adjustment question
    Senior Member Silvertone Jockey's Avatar
    Apr 2012
    188
    Given: 1/0
    Hello, its been awhile. I hope everyone is enjoying a life of health and prosperity, or a least still getting two feet on the ground in the morning.
    I have an Fender custom shop pickup in the bridge position of the only guitar that I actually play almost daily. Anyway I love that pickup, have no idea what model it is or any info other than it has a custom shop logo on the bottom. This pickup just has pole pieces, no bar magnet. It's only issue is the bottom e string has less gain the the rest of the strings. I play 11's so there is a fat wire. Can I just push the pole piece closer to the string to get more gain out of just that string? Thanks to all for the excellent advice that I have always received here.
    Oct 2015
    NEPA
    582
    Received: 48/1
    Given: 40/0
    Fiber bobbin? No. Plastic bobbin yes. Could be the magnet is weaker. You may end up lowering the other E side to try to even it out.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,445
    Received: 429/0
    Given: 468/0
    Most of the time you can, BUT...
    The pickup is likely potted. That pole piece is likely a magnet. Any tiny anomalies or texture in on the surface meeting the potting component is fused pretty securely. Also, the coil is likely wrapped directly around the poles. I've changed flat poles to a modern stagger on several pickups, but I did ruin one once in the attempt. I moved the pole beyond the coil a tad and when I tapped it back in place I severed the coil. Being as the magnet wire is right against that pole and there is likely a hard wax holding everything in place it's the end poles that pose the most at risk for this sort of thing. If you love the pickup you would be better off enlisting the services of a pro to handle this. They would surely put the pickup in a potting wax and then adjust it while it was soft. Or, they would research the pickup for turns and wire gauge and then re-pole the low E (and possibly the A) string poles with a stronger magnet and rewind the pickup. My $0.02 on the matter is that the pickup adjustment is biased at the ends and bridges are radiused, so it should be possible to strongly favor the low E. Perhaps there is something in your gear that is cutting off LF above much of the low E strings frequency coverage.
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Apr 2012
    188
    Given: 1/0
    Glad I asked. I didn't explain that correctly. It's the high e string thats weak. I don't remember it being potted when I changed to cover on it. Also don't remember if its fiber or plastic bobbin.
    I don't know how or why but that single coil pickup has the best metal sound of all my guitars. Humbuckers sound mushy in comparison. I would definitely be bummed if I damaged it trying to mess with the pole piece
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    Even warmed up the wire can break. I tried this and failed. The reason was the wire was wound directly against the pole piece and there was some internal corrosion on the pole piece surface, despite the wax potting. Just a slight and controlled movement was enough to kill it. It was a pickup I liked, but when I rewound and remagnetized it the sound was very much improved.
    May 2007
    pacific north west
    13,445
    Received: 429/0
    Given: 468/0
    High E or low E, it doesn't matter to the coil or the risk factor. I have the same gripe with a weak sounding high E. The guitar I use is rather dark and fat for a strat build. A light guitar. I attribute it to the acoustics and the high E just doesn't kick the wood like the other strings. I use 10's with an 11 replacing the high E (if you can call them 10's now ). That works out pretty well for me.
    If I were you I would investigate the pickup and try to discover what it is (in case you DO need to replace it) and if it's staggered. Rather than move the end poles I might move the other poles to alter the stagger profile, leaving both E poles alone. I would think a modern stagger would work for you. It depends on your bridge radius. This is what I'm calling a modern stagger. The real pickup guys here may have a different term.
    Or... Actually, I wouldn't move any of them!!! The reason is that you're playing metal with this thing so it's probably a bad idea to do anything that loosens parts in the pickup and compromises the potting. You risk microphony. So, again, I would suggest a professional.
    Proceed at your own risk.
    Supporting Member Tone Meister's Avatar
    Aug 2012
    North Carolina, USA
    645
    Received: 16/1
    Given: 13/0
    Lindy Fralin or Brian Porter would be willing and able to handle this. Fralin is in VA and Porter is located in ID.
    Lindy Fralin Pickups
    Porter Pickups
    Quote Originally Posted by km6xz View Post
    "I have come to the conclusion that the biggest risk to amp performance/reliability and "tone" is players reading the internet, not bad tube brands, and certainly not the often argued over capacitors."
    Oct 2015
    NEPA
    582
    Received: 48/1
    Given: 40/0
    By the time you pay a custom winder to fix a problem like this(with no guarantees), you might as well buy a new pickup. Put a pair of vise grips on it, twist slightly each way, pull up slightly. If it dies, buy new. If there is a winder living near you, he may have a guass meter to check the pole strength.
    May 2007
    pacific north west
    13,445
    Received: 429/0
    Given: 468/0
    Quote Originally Posted by mozz View Post
    ...you might as well buy a new pickup.
    ... If it dies, buy new.
    But the OP said:
    Quote Originally Posted by Silvertone Jockey View Post
    ... have no idea what model it is or any info other than it has a custom shop logo on the bottom.
    But I bet you could measure the DCR and email a picture and that spec to a custom shop and find out what it is.?. Anyway, I'm with you. I would try to ID the pickup and then if I could I would attempt a manual adjustment to the one I had, knowing I could replace it.
  1. Pole piece material?
    By peskywinnets in forum Pickup Makers
    Last Post: 11-14-2015, 02:10 AM
  2. Where to get pole piece assemblies machined?
    By tonemonkey in forum Pickup Makers
    Last Post: 01-19-2012, 05:10 PM
  3. The 'role' of a pickup pole piece?
    Last Post: 11-18-2010, 08:56 PM
  4. Fender pole piece spreads?
    By pete n in forum Pickup Makers
    Last Post: 05-22-2010, 12:29 PM
  5. The mystery of pole piece
    By Achiles in forum Pickup Makers
    Last Post: 03-10-2010, 07:19 PM
