Crown DC300A Oscillating
  • Crown DC300A Oscillating
    I have a DC300A on the bench that one channel was folding the top half early into a load. I couldn't get the original 2N5804 driver transistors, so I used a pair of MJ21194 transistors as replacements. I adjusted the bias for that channel, and it has no DC on the output. Now the amp goes into a big oscillation as soon as it clips into a load. I added a 200pf compensation cap as C119, which is shown on the schematic, but that didn't help.
    Do I need to pay big bucks for 2N5804's to make this work correctly?
    Or should I replace all of the output devices with MJ21194's on that channel?
    Or just try compensating caps elsewhere?
    Service Manual
    The parts list shows different caps for C107/ 207, depending on the output transistor grade.
    (Crown is big on graded outputs)
    Certainly Not an easy amplifier.
    I would contact Crown.
    They have been most helpful to me in the past.
      Have you taken notice of this little ditty about C119/ C219?
      DC-300A-C119_ C219.pdf
      "Used Only If Oscillation Occurs During Test"
        [ATTACH]47186[/ATTACH]
        Yes, I specifically added that cap to stop the oscillation, but it did not help.
          I replaced the MJ21194's with MJ15024's and that took care of it.
