Results 1 to 2 of 2
Thread: Supersonic 60 Hiss and Popping -- Got TSB?
    Chicago, USA
    4,908
    Received: 54/0
    The SS 60 seems to be famous for popping during channel switching, for hiss/noise in the reverb circuit, and for hiss when biased cold.
    From what I've read Fender ships the amps with extremely cold bias and some of the hiss problem goes away when you bias the amp normally. I also understand that fender issued a TSB regarding a fix for the reverb noise, as well as a fix for the channel switching pop. Reading on the forums it sounds like the channel pop fix involved a relay swap, but I can't find anything about fixing the reverb noise problem.
    If anyone can post a copy of the TSB I'd like to read it.
    Thanks.
    Junior Member
    Jun 2013
    19
    Received: 1/0
    Quote Originally Posted by bob p View Post
    Thanks.
    Id be great full if anyone could provide this information as well.
  1. Roland Cube 60 intermittent internal popping
    By fredcapo in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2018, 08:55 PM
  2. Fender Supersonic 60 combo Question
    By gtto in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-20-2016, 12:24 PM
  3. Fender Supersonic 60 reverb whistle
    By mikeydee77 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2016, 03:36 PM
  4. very loud popping-Roland Bolt 60
    By Trick in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-07-2013, 09:03 PM
  5. Diodes for marshall vs150h TSB
    By emux2 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2008, 04:09 AM
