Results 1 to 10 of 10
Thread: RCA JAN 83 rectifier tube flakes
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,066
    Received: 294/0
    Given: 45/0
    9
    Just purchased a 50's Military Hickok TV series tubes tester. It has a USN GE 5Y3WGTB and a RCA JAN 83 in it. The 5Y3 is sweet, but the big bottle 83 has flakes shaking around in it, as well as stuck to the inside of the bottle. I can see where they came from, mostly from one of the diode section shields? I don't actually know what they are called. Also, the bottom of the inside glass has something going on, on one side. Are these problems? The tester seems to work, but I have no way to verify it is accurate, and it is acting a little uneven at times. I went inside looking for possible electrolytic to replace and found this. Also, I just noticed a bit of fog inside the bottle, this cannot be a good thing.
    https://photos.app.goo.gl/79rhL9VITtD5R0uq1
    https://photos.app.goo.gl/oj8QxgIHqGweeq8I3
    Chicago, USA
    4,909
    Received: 70/0
    18
    replace.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,589
    Received: 1,477/7
    54
    Agree^^^
    All it takes is for a flake or two to get in between the plate and cathode, and your tube shorts, doing no favors to the transformer.
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,987
    Received: 1,055/15
    Given: 1,009/0
    12
    Guys.... the 83 is mercury vapor rectifier. The debris & "fog" seen inside = mercury metal.
    If it works, don't fix it, leave it alone. And expect to see a purple glow inside, also normal in mercury vapor tubes.
    Some years ago, also for a tube tester, I had to find a replacement, the 83 in it really was kaput. No luck with that. I subbed a pair of 1N4007 and got on with life.
    I see there are some up for offer on eBay. I've also tried chasing down 83's at the usual suspects - US and Canada tube dealers - to find they're "in the catalog but currently unavailable" so good luck with that.
    More to read up on the 83:
    Antique Radio Forums ? View topic - 83 Rectifier
    In any case, don't break the glass & sniff up the vapor, guaranteed bad for you! As in permanent brain damage.
    Jan 2013
    Cape Coral, FL
    2,066
    Received: 294/0
    Given: 45/0
    9
    There are NOS available on eBay, but not inexpensive. So, I am still confused as to whether I should replace or "leave it alone".
    Sep 2012
    Dogpatch-on-Hudson
    5,987
    Received: 1,055/15
    Given: 1,009/0
    12
    Quote Originally Posted by Randall View Post
    Knowing it could be replaced with a couple of 1N4007, wouldn't recommend sweating it too much. Try what's suggested in Antique Radio Forum: let your 83 warm up its filament, no hi voltage on the plates, see if that gunk inside the tube settles down to a glob or 3 of liquid mercury at the tube base. Then test it and if you get equal or near equal current on each plate then you're good to go. And if not, break out that pair of '07s, solder 'em in, and discard your shagged-out 83 at Home Despot or Lowes in that bin where we're s'posed to toss worn out CFL lamps.
    Supporting Member
    Staffordshire UK
    3,632
    Received: 352/1
    Given: 357/1
    18
    Looks like the 83 can take some pretty high voltages, way more PIV than a single pair of 1N4007s could accommodate http://www.mif.pg.gda.pl/homepages/f...s/093/8/83.pdf
    So before turning traitor and fitting silicon rectification, best to check the max Vac off the PT HT winding, eg unloaded with the 83 removed; if up near / past 350Vac then more than one pair of 1kV diodes are needed.
    Old Timer
    Chill-Ville, VA
    2,975
    Received: 541/4
    Given: 981/9
    16
    I get seeing the mercury inside the tube, but that one plate looks like it's lost a sizeable chunk of its outer layer of metal. I don't think we should be seeing that white section, when the rest of the plates look evenly covered. I say chuck it.
    But not before getting out the mercury and having some fun first... >:O
    Justin
    Feb 2010
    11,288
    Received: 1,238/21
    Given: 3,135/8
    22
    This SS kit seems to be designed for and tested in your application, feedback is good:
    https://www.ebay.com/itm/DIY-Kit-Sol...-/401494781406
    Oct 2015
    NEPA
    777
    Received: 153/1
    Given: 110/0
    4
    2 sides to the argument of replacing the 83 with SS. I vote no. I have a I-177B military tester and did lots of reading on this. Like was said, let the tester stand normal upright for a few minutes, power on. The mercury will get splattered all over if stored or used on it's side. If you go solid state, you are taking a load off the power transformer, which has a lot of sag to begin with, some of your reading may be off. They are not that expensive anyway.
    Antique Radio Forums ? View topic - WTB- for an 83 tube
  1. Replies: 15
    Last Post: 03-20-2017, 04:36 PM
  2. Replies: 2
    Last Post: 08-11-2010, 11:44 PM
  3. RCA Tube Victrola
    By peobus in forum Other Amps
    Last Post: 01-29-2008, 11:58 PM
  4. Suggestions on converting a RCA tube reel-to-reel
    By DinoSS100 in forum Conversion Projects
    Last Post: 01-24-2008, 08:30 PM
