Results 1 to 18 of 18
Thread: Epiphone Galaxie EA-33RVT adding grounded plug
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    This looks pretty straight forward , does anyone see a problem with adding a grounded plug to this amp , by simply using the chassis for ground , or is C17 the dreaded deathcap. I apologize if my schematic didn't post
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    On the schematic it does appear that all 'grounds' are common to the chassis.
    So attaching the mains safety wire to the chassis will work.
    And yes, remove C17.
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Quote Originally Posted by Jazz P Bass View Post
    Thank You !!
    Sep 2006
    290
    and be sure to run the hot to the fuse, then switch and tie the neutral directly to the other power transformer primary. Then install the ground to the chassis with the ground wire long enough that if the cord is pulled out it is the last wire to disconnect from the circuit.
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Quote Originally Posted by davohilts View Post
    the neutral connects to the other primary through S1 correct?? " then switch and tie neutral directly to the other power trans primary " threw me off , I just want to be clear. Thanks
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,647
    Received: 577/1
    The schematic shows one side of the mains going to the switch and the left side of the primary, and the remaining side of the mains going through the fuse to the right end of the primary.
    What he is telling you to do is run the left side of the primary directly to the neutral mains wire, and then move the switch to the other side of the primary between fuse holder and transformer.
    So mains current comes in through hot wire, through the fuse, then through the switch, then through the transformer, and back out to the mains neutral.
    Sep 2006
    290
    Thanks for making my note clear. It is always good practice to connect the hot side of primary to the fuse and then to the switch and connect the neutral directly to the other side of the PT primary. Then if the fuse blows you don't have line voltage past the fuse.
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Success !! Thanks to all for your support . Next thread will be biasing this amp. Thanks !!!!
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    The output circuit is 'cathode biased'.
    Measure across R26 (270 ohm cathode resistor).
    Stated on the schematic: 17 Vdc across that resistor is the expected idle voltage.
    You may want to lift the cathode bypass capacitor (C18) to see if that is affecting the bias voltage at all (it should not).
    Or simply replace it.
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Thank you Jazz P Bass , amp is on hold waiting for tubes .
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Quote Originally Posted by shortcircuit View Post
    Measuring today with old tubes one 6aq5 is 80%, one at 100% on tube tester ,Replaced C18 with a 25v 25uf cap, Resistor R26 in circuit 303ohms , voltage across R26 at idle 18.80 ohm , Voltage pin 5 on 6aq5 320VDC , pin 2 on 6aq5 18.55VDC so everything is running hot?
  12. #12
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Measuring today with old tubes one 6aq5 is 80%, one at 100% on tube tester ,Replaced C18 with a 25v 25uf cap, Resistor R26 in circuit 303ohms , voltage across R26 at idle 18.80 ohm , Voltage pin 5 on 6aq5 320VDC , pin 2 on 6aq5 18.55VDC so everything is running hot?Click image for larger version.
  13. #13
    Sep 2006
    290
    if you feel comfortable you might try the following to check the bias of the amp.
    1. Measure the voltage drop on the cathode resistor to ground. Write the value down.
    2. Divide this voltage by the actual measured value of the cathode resistor. This gives you the amount of current being drawn by both power tubes in milliamps. Write this value down.
    3. Measure the voltage on the plates of the power tubes to ground. Write this down.
    4. Now, subtract the voltage from the cathode resistor in step 1 from the voltage measured on the plates. Write this value down. Take this value, and multiply it by the current (milliamps) from step 2. This will give you the dissipated power (in watts) of both power tubes. Write this figure down.
    5. Take the figure from step 4 and divide by 2. Write this figure down. This is the power dissipation (in watts) of each tube. For 6AQ5s in Class AB, if it is over 9 watts, then you need to install a higher value cathode resistor. If it's 7.5 watts or less, you need to install a lower value cathode resistor.
    6. After installing the new cathode resistor, do ALL of the steps again to see what you now have. You may have to repeat this process several times to get it dialed in, but it is worth it, and your ears will thank you.
  14. #14
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Thank you! came up with 9.33
  15. #15
    Sep 2006
    290
    Looks pretty close, it would be interesting to check with a set of matched tubes. Good job.
  16. #16
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    Have a new set of tubes, will post results later on , waiting on some caps I ordered , as limited as they were I miss our RadioShack
  17. #17
    Supporting Member
    Jan 2018
    Michigan
    112
    Received: 4/0
    Given: 5/0
    After installing new tubes and a few caps my readings increased from 9.33 to 9.48 , raised R26 from 270 ohm to 384 ohm ( 330 + 50 ohm ) and am now at a happy 8.85 Thank You !!
  18. #18
    Sep 2006
    290
    Great job, I love gibsons even though they are such a pain to work on! Enjoy!!
  1. Epiphone Galaxie 25 - Anyone want a job? :-)
    By sashua in forum Build Your Amp
    Last Post: 11-18-2017, 03:30 AM
  2. Source or Replacement for Gibson Epiphone Chokes - Epiphone Ensign EA-14RVT
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-05-2012, 12:54 AM
  3. Epiphone Galaxie 25
    By jvm in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-13-2010, 08:16 PM
  4. Adding a grounded plug, need help
    By Warped in forum Other Amps
    Last Post: 03-30-2008, 03:31 AM
  5. Epiphone Galaxie 10 amp mods
    By Steve A. in forum Mods & Tweaks
    Last Post: 12-01-2007, 08:00 PM
