Results 1 to 31 of 31
Thread: Orange noise
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Orange noise
    I have a AD 200 bass mk 3 here with a loud buzz. I can kill it with the MV and by pulling v2 or v3 . The only scem i can find is on prowess amps but its not correct to this amp. This pcb is dated 2006. (ill try calling Orange tomorrow) , I tried clipping in a 50uf filter cap at all the plates v1/2/3 - it doesnt affect the noise unless i clip it to the plates of V1--but then i have almost no volume .
    i did find about 18 vdc at the grids of V2 -- that shouldnt be there, yes ?
    the shielded cable grounds are good
    side note = theres a cap in here , that i think is a coupling ( traces are on both sides of pcb-cant see the bottom) , but its got strange labeling. Can someone decipher this ?
    R60 MKT 400 A9 10MRL19
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    You found 18V at the grids, what was at the cathodes and plates?
    How about a pic of that component with the marking.
    May 2010
    Sioux Falls, SD
    5,325
    Received: 267/0
    Given: 241/0
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    pin 3 33vdc
    pin 8 33vdc
    pin1 202vdc
    pin 6 198vdc
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    With the cathodes at 33V, the 18V at the grids is not necessarily a problem.
    Without some kind of schematic, even close, it's all guesswork as far as hum.
    Sometimes there are DC heaters for the early preamp stages. See if you can find out if there are AC or DC heaters on the preamp tubes.
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    all heaters are AC --all tubes
    orange wont send me a scem. any authorized guys on here ?
    heres a vid of the noise =
    https://vimeo.com/259402089
    edit---the amp owner knows a rep there , so hes trying to get me the scem.
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    513
    Received: 21/0
    Given: 14/0
    It's obvious, but have you tried a new 12AX7? Sometimes I have seen that noise (with more bass component) in defective tubes. Specifically in ECC83 JJ and Tesla E83CC (same type of construction).
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    yep--swapped out every tube.
    i cant get directly to the filter caps-they are vertical pcb and some of the traces are on the bottom .. so i clipped in a 50uf at all the plates of the preamp tubes. Would that cover it , or do i need to get directly to some of the caps "first in line" ? if that makes sense
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,664
    Received: 588/1
    Ok, your funny voltages look like they are on a LTP phase inverter. The plate voltages are close, the cathodes are the same. probably wired together, and the grids have the DC the cathode has, but your meter cannot read it due to the high resistances. Looks normal then. Instead of measuring pins 2 and 7 to ground, try measuring 2 to 3 and 7 to 8. I bet you only get a volt or two.
    You can't tack a filter cap on the tube plates, that acts like a giant tone control rolling off your audio.
    Pulling V1 stops the noise? Pins 2 and 7 are grids. Try grounding each of those one at a time. Either kill the hum?
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    YES--THATS WHAT I SEE
    NO--PULLING V2 /3 KILLS THE BUZZ
    ON V1-- GROUNDING GRIDS -- 2. NO STILL HAS LOUD BUZZ 7. KILLS VOLUME-- STILL BUZZ IN BACKGROUND / QUIETER
    V2-- 2. KILLS BUZZ 7.KILLS VOLUME, STILL BUZZ IN BACKGROUND / QUIETER
    V3 2. KILLS BUZZ 7. KILLS VOLUME , BUZZ STILL IN BACKGROUND -QUIETER
    Junior Member
    Mar 2018
    Sweden
    14
    I'm thinking you are experiencing an imbalance somewhere in the phase splitting circuit?
    Here you have some unofficial schematics:
  12. #12
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    i think i have found the correct scems.....pm me for link
  13. #13
    Oct 2011
    286
    Received: 2/0
    Given: 11/0
    Try measuring heater (ac) voltage on preamp tubes, ground to pins 4/5 and ground to pin 9. They both should be around 3.15V AC
  14. #14
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    3.89vac
    3.34 vac
  15. #15
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    You said you can kill the buzz with the master. That leaves only V1 ahead of it so you can concentrate on that area.
    How about with the gain all the way down, does the master still bring the buzz in and out?
  16. #16
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    gain on 0 ...buzz still there , just quieter
  17. #17
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    Have you tried other tubes in V1 position?
    And instead of clipping that 50uF cap to the plate, clip it to the other side of the plate resistor. Any effect on the buzz?
  18. #18
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    [QUOTE=g1;482825]Have you tried other tubes in V1 position?
    yes
    no effect
  19. #19
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    765
    Received: 80/1
    Given: 49/0
    Nobody’s made a “white/pink” noise joke yet??
  20. #20
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    Don't miss your chance!
  21. #21
    Jan 2016
    Massachusetts
    765
    Received: 80/1
    Given: 49/0
    Okay, okay.... How ‘bout this one:
    Orange noise (the worst kind of noise), is also known ass 1/Sl noise due to it’s tendency to improve linearly with skill level.
  22. #22
    Feb 2010
    10,210
    Received: 360/1
    Given: 695/0
    So, of the schematics you received, none of them show the tone controls. But there is the d'Uur power amp drawing like in post #11. (edit: nevermind I see the pots are shown on the separate front panel board and what I thought were pots on the main drawing are connectors to the pots. Even so, the drawing in post #11 is accurate enough for everyone to work from)
    With master up, does turning all tone controls down to zero reduce or remove the buzz?
    Is this a circuit board amp? Are the tube sockets wired or mounted on the board? Can you post some pics of inside the chassis?
    What does the owner say about the history of the fault, just showed up overnight, or appeared gradually?
  23. #23
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
  24. #24
    May 2010
    Sioux Falls, SD
    5,325
    Received: 267/0
    Given: 241/0
    Have you tried Enzo's suggestion in post #9?
  25. #25
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    yes post 10
  26. #26
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    yes-pcb amp
    sockets are pcb
    turning down tone controls doesnt really affect it---the Gain pot does
  27. #27
    May 2010
    Sioux Falls, SD
    5,325
    Received: 267/0
    Given: 241/0
    Quote Originally Posted by Valvehead View Post
    yes post 10
    Apologies. Missed that one.
  28. #28
    May 2010
    Sioux Falls, SD
    5,325
    Received: 267/0
    Given: 241/0
    Just watched the video you posted. It sounds a lot like noise from a ballast- florescent lights, neon lights, etc. Are there any nearby? If you had say a bad input or loop switching jack or an open circuit somewhere and were near the right source, it might sound something like that. Grasping at straws a bit, I know.
    Edit: Make sure your AC plug ground is making it to chassis ground.
  29. #29
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    That crossed my mind too but i unplugged the lights to check that
    i will check the amp ground
  30. #30
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    ac ground is good ...tried a ground lift too
    also took the amp out to my garage to try it on different power
  31. #31
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Im starting to think either filter cap or coupling cap ?
  1. Orange OR100
    By FleshOnGear in forum Schematic Requests
    Last Post: 06-10-2016, 12:24 AM
  2. Replies: 26
    Last Post: 02-03-2016, 05:12 PM
  3. Orange
    By Valvehead in forum Schematic Requests
    Last Post: 06-23-2013, 08:53 PM
  4. Orange Rockerverb Noise Problem
    By brylord in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-24-2008, 06:23 PM
  5. Is my Orange really an Orange?
    By rocketpastthemoon in forum Guitar Amps
    Last Post: 04-09-2007, 03:56 PM
