Results 1 to 14 of 14
Thread: Is this a death cap?
    Oct 2014
    40
    1959 Gibson GA5 Skylark. Is the black beauty cap coming off the fuse a death cap?
    http://www.paleoelectronics.com/blog...5-from-msb.gif
    Thanks!
    Feb 2010
    10,200
    Received: 343/1
    Given: 672/0
    Yes. It's not shown on that schematic, but this one has it:
    Attached Files Attached Files
    Oct 2014
    40
    Thanks. So I can just clip a lead or completely remove it and it's safer?
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    Clip it out, right at where its soldered at each end. It's safer gone.
    Old Timer
    Jun 2007
    5,000
    Received: 16/0
    Given: 13/0
    Quote Originally Posted by Mick Bailey View Post
    Carefully remove it and sell it to somebody restoring a 1960's Gibson guitar.
    Have you replaced the original 2-wire ac cord with a 3-wire one?
    Oct 2014
    40
    Yea, I just replaced the cord, some capacitors and a resistor based on feedback in another recent thread.
    I have 4 bumble bee .022 caps now from a few vintage amps I've restored recently. All of them test .029-.044 which are still somewhat desirable in a gibson guitar but are a little on the high side. I might try them in my 2 gibson guitars first but I'll probably just sell them.
    Any idea what price to put them at on the market?
    Lifetime Member
    4,271
    Received: 52/0
    You don't mention - when you put in that 3-wire cord, did you also connect the green or green/yellow safety ground wire to the chassis in a manner that won't let it come loose and will guarantee that the connection stays absolutely electrically connected for many years?
    If you didn't, you just made the amp noisier and no safer.
    4,503
    Received: 116/0
    Given: 77/0
    Quote Originally Posted by R.G. View Post
    Good point! I used to always keep the ground wire short in amps and other equipment so as to eliminate the possibility of the hot wire getting yanked loose sometime in the future until Bruce Collins pointed out the error in my ways. D'oh!
    Steve A.
    Oct 2014
    40
    I soldered the ground wire to what looks like a washer and bolted it down on one of the transformer wires. It’s very secure and like steve a says below, the ground wire is extra long so if anything gets yanked out the ground is last to go.
    Old Timer
    Cornelius, Oregon
    1,346
    Received: 19/0
    Given: 49/1
    Quote Originally Posted by Triocd View Post
    It is better from a safety perspective to have a separate bolt to secure the ground wire instead of a transformer bolt. If someone replaces the transformer and neglects to reconnect the safety ground then you could have a major safety issue. If the safety ground is on its own bolt then the chance of it getting disconnected is much lower. It should also be bolted down with a nylock or keps nut and some nail polish on the top of loctite on the threads also helps to keep it secure.
    Greg
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,794
    Blog Entries
    1
    Received: 56/0
    Given: 34/0
    Quote Originally Posted by soundmasterg View Post
    Agree with your comments. But if someone can't even remember to reconnect a ground wire I wouldn't trust them replacing the transformer in the first place.
  12. #12
    Feb 2010
    10,200
    Received: 343/1
    Given: 672/0
    I think of greater concern is the heat cycling of the transformer (coupled with vibration) may lead to the nut loosening.
  13. #13
    Jun 2006
    California, USA
    3,521
    Received: 96/0
    Given: 45/0
    I agree. Of all the various fastening hardware in an amp chassis I find that the nuts on the transformer bolts are most frequently found to be loose. This is so even if they have proper lock washers between the nut and the chassis.
  14. #14
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,647
    Received: 577/1
    And loose power transformer nuts can even cause crackles and hum.
  1. Silvertone 1451: death cap and more
    By otto pärt in forum Repair and Restoration
    Last Post: 07-11-2018, 02:10 AM
  2. Replace Death Cap with Safety Cap?
    By Axtman in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-04-2014, 05:54 PM
  3. Death cap
    By cowboy in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-04-2014, 12:55 AM
  4. When a Death Cap Commits Suicide...
    By Dave Curtis, dB AudioTech in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-06-2009, 08:01 PM
  5. Your take on the death cap issue
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-09-2008, 03:23 AM
