Does hand winding mean hand on the wire?
  • #31
    Jon, you're a comedian if not a pickup maker.
    sigpic Dyed in the wool
    • #32
      Hehehe...funny stuff
      -Stan
      ...just transferring wire from one spool to another
      Stan Hinesley Pickups
      FaceBook
      • #33
        But I'm the only comedian with a Leesona 102 and a multi bobbin hand guided and computer guided winder of my own design.
        They don't make them like they used to... We do.
        www.throbak.com
        Vintage PAF Pickups Website
        • #34
          Originally posted by JGundry View Post
          But I'm the only comedian with a Leesona 102 and a multi bobbin hand guided winder of my own design.
          You should take them on tour with Steven Wright. He need's a stooge.
          • #35
            You all crack me up!!!!
            www.guitarforcepickups.com
            • #36
              That would never work. Steven Wright still thinks PAF's are hand wound.
              www.throbak.com
              • #37
                Great. Well there's the whole basis for your act. Steven wright needs to incorporate a bit of slapstick into the show.
                • #38
                  The problem is Steven is too busy powering his pedal driven winder while having his hands full with the winding to do anything else.
                  www.throbak.com
                  • #39
                    Shame. Well I suppose you'll have to go back to pedalling your pedals and showing people around your antique winder mausoleum.
                    • #40
                      One man's Library of Congress is another man's antique book mausoleum. It just depends or your perspective, and thirst for knowledge.
                      www.throbak.com
                      • #41
                        The early bird gets the worm, but the second mouse gets the cheese.
                        If everything seems to be going well, you have obviously overlooked something.
                        Ambition is a poor excuse for not having enough sense to be lazy.
                        If at first you don't succeed, destroy all evidence that you tried.
                        A conclusion is the place where you got tired of thinking.
                        • #42
                          As Sam Lee Guy once said during a moment of clarity,
                          "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life"
                          That's thought provoking.
                          • #43
                            Those were Steven Wright quotes by the way...
                            • #44
                              The man's a legend.
                              • #45
                                Originally posted by kevinT View Post
                                You're right, it does jerk to a certain degree. My tensioner's arm bobs up and down because of this. I have minimized it... but i don't think you can, with the setup that i have, get the bobbing/jerking totally out of the picture. I also have a felt clamp that maintains light tension between the tensioner and the rollers on the wire guide of my machine. I think this helps minimize it as well. ...
                                That is funny that you mention this....when i started using my machine i had this problem. I would program the machine to do a certain number of turns at a slow start speed to get the coil started and then it would kick in to the general winding RPMs that i programmed....many times the wire would snap. I had to find the "sweet spot", were the jerk was minimized between the slow start speed and regular winding speed.
                                It sounds like you could use a dancer, which can be as simple as a very light spring made of music wire that bobs up and down in unison with bobbin rotation. Think of a fishing pole as the model.
