Results 1 to 5 of 5
Thread: Gibson Skylark Crestline GA-5 Lay out
    New Member
    Mar 2018
    Medina, OH
    2
    Does anyone have a point to point layout of the Skylark Crestline GA-5 they'd be willing to share?
    Thanks.
    Aug 2009
    Near Nashville
    594
    Received: 27/0
    Given: 18/0
    Are you looking for the GA5 Skylark with a single 6V6 power tube? I think I have a gut shot of the Epiphone version (same amp) if that helps.
    New Member
    Mar 2018
    Medina, OH
    2
    Quote Originally Posted by dmartn149 View Post
    No, mine is the Skylark Crestline GA5. It has 5 tubes. 6X4, (2) 6AQ5ís, 6C4, and 6EU7. I believe the 6X4 is the power tube.
    Old Timer
    Chill-Ville, VA
    2,592
    Received: 132/1
    Given: 270/6
    Your 6X4 is the rectifier tube. The 2x6AQ5s are the power tubes, and the 6C4 & 6EU7 are preamp tubes.
    Justin
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,794
    Blog Entries
    1
    Received: 56/0
    Given: 33/0
    I had worked on one of these a while back so here are a few picks. Sorry I did not think to take pictures of the front wiring of the pots and jacks. Also, note that I wired the neutral line in series to the switch. Knowing better now I would have wired fuse (hot wire) in series to the switch and neutral wire directly connected to other side of transformer primary. Oh well I know better now, but back then I wired it exactly as I found it. Well I cut out the death cap and added a 3 prong power cable.
ID:	47615   Click image for larger version.
ID:	47616   Click image for larger version.
ID:	47617   Click image for larger version.
  1. Gibson Skylark GA-5T Crestline
    By Pdavis68 in forum Vintage Amps
    Last Post: 07-29-2015, 03:24 PM
  2. Replies: 27
    Last Post: 06-30-2015, 02:42 AM
  3. Gibson Skylark GA-5 Weirdness
    By flythair1 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2011, 06:14 PM
  4. Gibson Invader GA-30RVT Crestline Power Transmission Help
    By Bmxbarspin724 in forum Vintage Amps
    Last Post: 02-11-2011, 11:40 PM
  5. Replies: 1
    Last Post: 01-21-2011, 08:23 PM
