Results 1 to 11 of 11
Thread: Tascam 464 random auto-ttape shut-off kicking in mid tape
    New Member
    Mar 2018
    4
    Hey, my first post to the forum. Nice to know the forum is here. Great resource, the true spirit of the Webb.
    I have a 464 tascam that has been with me 20 years. it has an auto-shut-off feature that seems to be kicking in mid-tape during recording sessions. In other words, the damn thing stops recording mid-session and mid-tape. I hear the typical mechanism sounding that sounds like the unit hit the end of the tape. The play head recedes, the counter remains where it is. There is no slack in the tape when removed to check..
    It happens with new tapes freshly unpacked and it happens anywhere at anytime. Very strange.
    My guess is, some part in the unit either needs a good cleaning...oiling....or a replacement.
    I was hoping for some troubleshooting tips from those in the forum who have the same model, a similar model, a similar problem, or who simply have the experience with the machine and have a pretty good idea of what it could be.
    Looking forward to hearing your ideas and expertise. Thank you!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,644
    Received: 573/1
    Hi, thank you for posting here.
    Did we look at the tape counter and was it at zero or close?
    If I recall, there is an RTZ button. In that group of various control buttons near the display, do they all feel the same? They are tactile switches, so they ought to have the springy pop feel to them. Does any feel kinda flat or overly sensitive?
    New Member
    Mar 2018
    4
    Tape counter intact
    Hi Enzo, good idea. I checked it and the tape counter remains intact...it doesn`t reset. And the random stopping of the mechanism which transports the tape is not linked to the counter. All the little buttons feel the same. Springy pop is intact. Hardly ever used that bay. Acts and behaves like someone (or something) just pushed the STOP button. ghostbusters?
    30,644
    Received: 573/1
    OK, so counter could be on any number when it happens.
    In fact, it could even be the stop switch failing.
    Do you have the service manual?
    New Member
    Mar 2018
    4
    It could be that
    It could in fact be a failing stop switch. I do not have the service manual. Would love to be in possession of it though. Anyone have it? And would anyone be willing to post it for a download here?
    Old Timer nosaj's Avatar
    Sep 2011
    Pace, FL
    1,869
    Received: 245/20
    Given: 25/5
    Quote Originally Posted by FourTrackAintDead View Post
    Didn't see it mentioned, but is this on any tape? new or old?
    I seem to remember years ago I would end up with tapes where tension was wonky after lots of use and the fix was to fast forward to the end then rewind which would even out the tension.
    nosaj
    New Member
    Mar 2018
    4
    New or Old Tape
    Quote Originally Posted by nosaj View Post
    nosaj
    hey nosaj,
    I thought the same, but it happened with a freshly opened tape last time. I am thinking it must be something else....perhaps there is a way to adjust this sensitivity.....any ideas?
    thanks for the tip about the FFWD and then RWND. will try that in the future if i find an old tape i want to re-record on.
    maybe someone has the service manual for the 464? i would love to read it.
    Sep 2011
    Pace, FL
    1,869
    Received: 245/20
    Given: 25/5
    hey nosaj,
    This is the closest Portastudio service manual I can find. maybe you can glean what you need from it? It's too big to upload here
    https://elektrotanya.com/tascam_488_.../download.html
    At the bottom of the page you will see a processing link wait about 30 secs then it will change to get manual.
    nosaj
    Dec 2008
    Wernersville, PA
    12,351
    Received: 105/0
    Given: 31/0
    What 'length' tape are you using.
    These units do not like C-120's.
    Feb 2010
    10,192
    Received: 333/1
    Given: 661/0
    Do you know how to hold the cassette detection switches with your finger to get the mechanism to go into play with no tape inserted?
    Put it in play and put some drag on the take up reel. Does it have good torque?
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,671
    Received: 44/0
    What he said. Insufficient takeup real torque is a common cause of this. I don't think this model has a physical tape tension switch. If I remember correctly it's optical or magnetic. If the taken hub stops intermittently it will shut off. We used to have torque measurement guages. If you can get it to play without a cassette you can feel the torque with your finger on the spinning hub and force it to auto stop.
  1. Problem with Tascam Portastudio 464 pitch control
    By Manu in forum Music Electronics
    Last Post: 10-30-2015, 10:32 PM
  2. anyone familiar with Tascam 464?
    By dai h. in forum Music Electronics
    Last Post: 04-03-2014, 01:20 AM
  3. Replies: 12
    Last Post: 10-18-2012, 11:02 AM
  4. Big Muff TS looking for Mid-scoop to mid-hump control?
    By tubeswell in forum Theory & Design
    Last Post: 07-13-2011, 08:16 PM
  5. Tektronix 464 or 465?
    By Satamax in forum Music Electronics
    Last Post: 02-18-2009, 07:42 AM
Tags for this Thread
