Results 1 to 16 of 16
Thread: Hide Glue for Tolex
    Dec 2008
    793
    Received: 27/1
    Given: 5/0
    11
    Hide Glue for Tolex
    I'm thinking of using hide glue for re-tolexing a vintage amp -- not because I'm trying for vintage-correctness, but because I'm chemically-sensitive to the solvents in contact cements. To use them, I have to be outdoors or in an area ventilated by a high-powered fan and use a respirator mask with organic vapor cartridges or I'll end up feeling like I'm coming down with the flu for a couple of days. Then, I have to store anything done with contact cement in an attic or some other outdoor shelter for a few days until it's done outgassing. When you add up all that trouble, having to heat hide glue starts to look easy. Organic vapor cartridges are not cheap.
    Any tips for tolexing a cabinet with hide glue? I read that you have to work quickly to avoid having it set up on you. Do you apply it to the tolex, the wood, or both?
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,348
    Received: 234/2
    Given: 76/2
    15
    see this post
    tolex/adhesive frustration
    and associated discussion. Hide should work ok but is tricky compared to some "green" water based contact cements also mentioned.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Quote Originally Posted by Rhodesplyr View Post
    You´ll go crazy with hide glue because they require a lot of hardware to work with.
    Fender used a hot table on which he could brush glue on Tweed or Tolex without hurry, it started cooling only when lifted and applied to cabinet.
    And even so he split Tolex (or Tweed) into 4 pieces so he coukd fully apply one while others were still warm.
    And Acoustic (where I learnt yhen Technique) and most others (up to and including Mesa Boogie) used the wonderful Potdevin hot glue spreaders , I´ll post a video.
    Problem is they cost quite a fef thousand dollars.
    No big deal for any Factory (or even the US Post service which use them to apply lickable glue to stamps) but impractical to small users:
    Chicago, USA
    4,909
    Received: 76/0
    18
    Great video. Thanks for posting it.
    I never knew that Mesa used a huge die and a roller press to cut the tolex to pattern. They sure waste a lot of material.
    I also like the glue application machine that uses a wet roller.
    I hadn't realized that the Mesa cabs use a single piece of tolex that results in a single seam on the bottom of the cab, where the old Fender cabs would use two pices of tolex that resulted in 2 seams. I wish the cameraman would have done a better job showing how they trimmed the seams on the cabinet. He really dropped the ball on that part of the video.
    This video reminds me of why I avoid re-tolexing. And why I won't pay very much for a cab that needs to be re-tolexed.
    Jun 2006
    California, USA
    3,559
    Received: 160/0
    Given: 92/1
    17
    Quote Originally Posted by bob p View Post
    ...the old Fender cabs would use two pices of tolex that resulted in 2 seams...
    Bob,
    That would be four pieces and four overlaping seems for an old Fender.
    Cheers,
    Tom
    Chicago, USA
    4,909
    Received: 76/0
    18
    I must be remembering things wrong, Tom. I remember the Fenders using a single piece of tolex on the bottom, and a second piece that wrapped around the bottom edge, up one side, across the top, down the other side, and around the other bottom edge, to create two seams. Am I remembering it wrong? As you can tell, I avoid doing this sort of thing.
    Chicago, USA
    4,909
    Received: 76/0
    18
    I guess I'd better go take another look at my Fender amps.
    From casey4s' old drawings:
    http://www.guitarkitbuilder.com/img/tolex10.jpg
    Dec 2008
    793
    Received: 27/1
    Given: 5/0
    11
    I appreciate the warnings.
    Maybe I'll try Mojotone's water-based contact cement and see how that works.
    Chicago, USA
    4,909
    Received: 76/0
    18
    AES/CED also sells tolex adhesive by the gallon. I don't know how it compares to the Mojo product, I've never used either one.
    Oct 2007
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Cool. Try it first: join, round and sand 2 pieces of wood, you´ll have 2 corners which is the hard part, and you can try seams on the flat sides.
    I have not had luck with water based contact cement, so it´s the solven type for me, buy kept reading and I think I pplied too little.
    I should have applied more, or let dry and apply a second layer (on each side), the key seems to be that surface should look somewhat shiny, glue shpuld be "visible" even when dry.
    If it looks like "there´s nothing there" ... probably there´s not enough.
    Even simpler: try plam sized bits of Tolex testing different techniques, and once you´re in the ballpark, test the full rounded corner, seams, etc.
    Supporting Member
    Apr 2007
    1,070
    Received: 63/0
    Given: 43/0
    14
    I tried the water based adhesive, but like Juan, had poor luck, ended up peeling the tolex off, and applying it wet. That worked, but I had to keep smoothing the wrinkles out until it dried. I finished the rest of the cab with contact cement!
    I realize you have problems with the solvent based stuff, but the method I have settled on is applying DAP to the wood, and then spraying 3M 77 on the tolex. I think I wasn't getting the tolex covered completely when brushing the adhesive on it, and would sometimes get "bubbles" where it didn't adhere.
  12. #12
    Chicago, USA
    4,909
    Received: 76/0
    18
    3M 77 -- does that stuff give you any working time or is it a one-shot deal?
  13. #13
    Cornelius, Oregon
    1,419
    Received: 111/0
    Given: 204/2
    15
    I learned how to cover cabinets from Conrad Sundholm, of Sunn fame. He used and still uses hide glue. It doesn't give a lot of time to work with it before it hardens, but you just need to make sure your pieces are cut properly and you are ready to lay it down. Use a roller and do smaller areas at a time and save the corners until last and it works great. Prior to learning from Conrad I used contact cement and the 3M spray stuff. I had by far the best results with hide glue. YMMV.
    Greg
  14. #14
    Supporting Member
    Apr 2007
    1,070
    Received: 63/0
    Given: 43/0
    14
    bob p, my method leaves only a few minutes after contact, before it gets really difficult to separate. I use strips of tape to ensure that the piece I am installing is correctly orientated. (Most important when using different colors of tolex!)
  15. #15
    Chicago, USA
    4,909
    Received: 76/0
    18
    thanks. which DAP product goes on the wood?
  16. #16
    Supporting Member
    Apr 2007
    1,070
    Received: 63/0
    Given: 43/0
    14
    I use the original DAP "Weldwood" contact cement, and wait usually 15 minutes before assembly.
  1. Anyone have a hot glue gun they like. What glue for what purpose?
    By David King in forum Tools and Coil Winding Gear
    Last Post: 10-26-2014, 11:28 PM
  2. Replies: 33
    Last Post: 03-10-2010, 07:33 PM
  3. (UK based question) What glue for tolex/ tweed etc?
    By The Captain in forum Cabinetry
    Last Post: 12-12-2008, 12:07 AM
  4. Glue to use on overlapped tolex?
    By daz in forum Cabinetry
    Last Post: 10-21-2008, 02:57 AM
  5. What have YOU used to glue Tolex with?
    By nicksorenson in forum Build Your Amp
    Last Post: 08-30-2007, 06:31 PM
