I just replaced a broken encoder from an old Fender cyber twin amp. Fender no longer make the part that broke so I found a modern ( unbranded) encoder. The original and the new part are both 4-bit Grey code 16pos encoders.
The new part doesn't seem to be acting the way it should. Instead when you turn it the values jump erratically up , and down, instead of going in increments up or down.
Any ideas with what the issue could be?
