Results 1 to 5 of 5
Thread: Vintage Baldwin Organ Amp (simple fix?) (help)
    New Member
    Mar 2018
    3
    Hello all!
    To preface this, this is my first post on this forum so if i've posted this in the wrong place then please direct me to the proper section.
    The problem at hand is my 1960s Baldwin organ amplifier. It's been working fine since I picked it up a couple months ago but the inside construction of the cab was always worrisome. Alas my worst nightmare happened and on my way to a gig i picked up my amp from its handle and disassembled in front of me. So here I am seeking advice on how to fix my amp. The construction of the amp seems to be very simple so I assume that this is a very easy fix but I don't know enough about amps to see where the problem is.
    Here are some photos:
    So what i've deduced so far is that when I plug in the little plastic squares into their respective compartments my orange power indicator light turns on. The only wires that are not connected to the amp are the ones seen in the last picture. I don't know where the wires are supposed to connect and i suspect that is the reason i can't get any sound through my amp despite there being power.
    Thank you for taking the time to read through this, hopefully someone can point me in the right direction, I'm very eager to learn and to fix this problem!
    Aug 2012
    Great Black Swamp
    1,828
    Received: 72/0
    Given: 181/1
    The black and white wires with the push-on connectors look like they'd go to the speaker. See if there are tabs on the frame of the speaker, verify whether or not anything is attached. And allow me to advise you to be careful! Always double-check that the amp is not plugged into the wall and has been allowed to sit for some time while the power supply discharges. You could get a nasty shock. Also, shorting those wires together while under power will result in damage to the amp.
    edit: the reason I say the wires might go to the speaker is that I can't see from your pictures what else may connect to it. Be sure to double check, maybe additional pictures (good job with the ones you took!) will help us 'see' to finish the repair.
    New Member
    Mar 2018
    3
    Thank-you for pointing me in the right direction eschertron! I took your advice and looked at the cabs speaker and noticed two little metal pieces attached to the speaker.
    ^ Noticed that they were kinda twisted
    After that I put the wires in their respective holders and suddenly sound took the place where silence once was
    Thank you again, you were a tremendous help.
    Now to reinforce the structure of the cab!
    Aug 2012
    Great Black Swamp
    1,828
    Received: 72/0
    Given: 181/1
    Glad to be of help. I hope the cabinet repair goes as smoothly as this.
    And welcome to the place! You will find many knowledgeable minds here who are willing to help others with questions and repairs.
    New Member
    Mar 2018
    3
    I believe it should, the construction of the cab is not very complicated so I'm sure the cab repair will go smoothly. I'm very happy i've found this community I'm very interested in learning more about amp repair and whatnot.
  1. Baldwin Vintage Amp conversion
    By jonton26 in forum Conversion Projects
    Last Post: 04-27-2018, 06:25 PM
  2. Baldwin organ tube amp
    By baddog in forum Conversion Projects
    Last Post: 07-24-2015, 03:11 AM
  3. Newbie deciding to not high-jack a baldwin organ amp thread
    By uncle_fly in forum Conversion Projects
    Last Post: 12-23-2011, 11:14 PM
  4. Baldwin model 40 organ power amp?
    By spsimmons in forum Schematic Requests
    Last Post: 05-19-2010, 09:39 AM
  5. baldwin organ amp to guitar amp conversion
    By rochotte in forum Conversion Projects
    Last Post: 10-26-2008, 02:20 AM
