Results 1 to 14 of 14
Thread: 2017 fender 65 deluxe reissue
    New Member
    Mar 2018
    Usa
    3
    0
    Hi I am new to this forum.
    I have a stock fender 65 deluxe reissue dated 2017. I didnt like the harsh sounds thru the fender del strat single coils.
    I used fender deluxe reverb modifications posted by swinging.lil.guitarman at ted weber amp board dated 2001.
    Did most of the mods less spkr. Also installed jjs tubes. The only thing I did not remove yet is the treble cap c7 . It sounds way better. I do have a question
    I used a bias probe to see the ma and it was 45 on my fluke after amp was warmed up 5 to 10 mins. I have yet to find out true info on how to correctly bias this. I am trained , experienced in all safety . Please help
    Thank you for your time
    May 2010
    Sioux Falls, SD
    6,325
    Received: 1,220/1
    Given: 950/1
    16
    This might help.
    Weber Bias Calculator
    New Member
    Mar 2018
    Usa
    3
    0
    Thank you for this!
    Btw I found an old marshallforum post that debunks the posts seen these days on biasing .
    Feb 2010
    11,753
    Received: 1,613/23
    Given: 4,125/11
    22
    Quote Originally Posted by Kt500 View Post
    How about a link so we can read it?
    Supporting Member
    Staffordshire UK
    3,768
    Received: 518/1
    Given: 468/2
    18
    Some bias probes require the meter setting to current mode, others use a current sensing resistor and so require the meter being set to voltage mode.
    So best to check the probe's instructions and re-measure.
    New Member
    Mar 2018
    Usa
    3
    0
    Titled Biasing-70%vs90%vsPlate currentvsCathodecurrent by wilder amplification
    Am using a mobile phone
    May 2014
    St Louis
    525
    Received: 28/0
    Given: 403/0
    6
    For convenience:
    http://www.marshallforum.com/threads...current.10890/
    1 Not allowed! Not allowed!
    Feb 2010
    11,753
    Received: 1,613/23
    Given: 4,125/11
    22
    Quote Originally Posted by Audiotexan View Post
    Funny you should bump this, I remember following up on it and finding that thread. Could not make heads or tails out of what on earth he was on about.
    I think he tries to separate plate dissipation from screen dissipation and does some math tricks that end up to the users detriment.
    (I have never heard of the 90% rule he talks about and I think it is a 'straw-man' that is creating more confusion rather than explaining anything)
    May 2014
    St Louis
    525
    Received: 28/0
    Given: 403/0
    6
    Yeah, what can I say. Still catching up on what I've missed!
    Quote Originally Posted by G1 View Post
    I hadn't either until now.
    Seems to be have been running rampant on their site at some point though (according to thread snippets contained therein).
    Maybe I'm just ignorant of the issue since I haven't ever used one of these aftermarket bias probes. /shrugs
    Last edited by Audiotexan; 05-04-2019 at 04:24 AM. Reason: Correcting auto-correct error (phone)
    Feb 2010
    11,753
    Received: 1,613/23
    Given: 4,125/11
    22
    Well, it seems some are trying to compensate for screen current when biasing via cathode current. Allowing for 90% because of it is crazy, but what Wilder suggests is no more correct. He says to add the screen max. diss. and bias for 70% of total screen + plate diss. when using cathode current to bias. Again, you end up WAY hot. His example for EL34 is to add 8W (screen max) to 25W (plate) and set cathode current to 70% of 33W. So you end up with what, somewhere around 30% high?
    As far as I know, screen current is typically around 5% of plate current? If someone wants to argue to allow an extra 5% current when measuring at the cathode, I have no problem with that.
    This other stuff is totally nuts.
    Nov 2013
    303
    Received: 117/11
    Given: 38/0
    6
    anytime you read about biasing hot is better,think this:"are these guys trying to sell more tubes?"
    2 Not allowed! Not allowed!
  12. #12
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    2,133
    Blog Entries
    1
    Received: 336/5
    Given: 230/0
    11
    Someone posted on that thread "This is why Randall Smith's amps are not adjustable." Which might be partly true in the respect that they wouldn't want noobs setting the idle current at 90% dissipation. But the real reason is Mesa wants to sell tubes and keep their customers at the mercy of their design. Never heard of this 70% vs 90% debate before either. That Marshall thread is confusing to read as per the examples G1 pointed out.
    3 Not allowed! Not allowed!
  13. #13
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,393
    Received: 1,413/21
    Given: 1,196/0
    14
    Quote Originally Posted by DrGonz78 View Post
    Early on, Mesa/Boogie amps DID have bias adjust, surprise! Back in the mid 70's when they were just starting up. Sure, Randall got tired of having to respond to warranty repair demands when amp owners or their friends with screwdrivers whacked the bias up to red plate territory. "But that's the only way amps sound good!" In order to cover his, uh, posterior, Mr. Smith left out the bias adjust. And that was all before Mesa were selling tubes as a sideline. Once tube sales commenced in the 80's, then the advice was "try 'em all, find which color makes your happy, and stick with them." For those who haven't encountered Mesa output tubes, they sort by emission matching and assign colors to various levels. Of course there's never been a guide to which color means what in terms of emission, so customers have to blindly select among yellow, red, blue, green, grey etc. Also, what music store keeps a selection of all colors available? You guessed it: none. So Mesa tube buyers can purchase direct and keep UPS/Fedex rich while they endure the color selection process. Phooey!
    Enjoy. Every. Sandwich.
  14. #14
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    1,793
    Received: 647/1
    Given: 1,478/1
    11
    I'm sure the question has been asked and answered long ago, but, is there a chart that shows the plate current/dissipation relative to their 'color-coded' matched tube sets? This would, of course, depend on what amp of theirs is used. Even with other brands of tubes that can be purchased in matched sets, one doesn't really know what the plate current/dissipation is until you install them and check the current, whether by current probe, measuring across a plate resistor or cathode resistor or IR drop across the Primary leads of the Output Xfmr and computing what that current is, noting if more than one tube is installed, do you know for sure what the current sharing is.
    BTW, if you're really measuring 45mA thru the cathodes of your 6V6GC power tubes, you're WAY too hot.
  1. Fender 65 Deluxe Reverb Reissue video demo
    By spinal in forum Guitar Amps
    Last Post: 07-24-2016, 05:34 AM
  2. Fender 65 Deluxe Reverb Reissue video demo
    By spinal in forum Vintage Amps
    Last Post: 07-23-2016, 09:59 PM
  3. Fender 65 Deluxe Reverb Reissue Power Transformer?
    By Tonestack in forum Guitar Amps
    Last Post: 07-10-2010, 02:43 PM
  4. 65 Deluxe Reverb Reissue
    By rdoyle in forum Guitar Amps
    Last Post: 01-27-2009, 04:14 AM
  5. 65 Deluxe reissue pots
    By Daveg in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-17-2008, 12:13 PM
