Page 1 of 2 12 LastLast
Results 1 to 35 of 62
Thread: Bias problems---
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Bias problems---
    working on an orange TH-30 . It has 2 of the el84s red plating , the other 2 do not. Its not the tubes .
    Looking at the scem , ive checked all resistors from V5 all the way to pin 2 of the el84s , ground is good , no bad solder joints , and while i had the pcb up i replaced the .1 caps , c45 / 46 coming out of V5 .
    with no el84s installed im getting 280vdc at pin 2 of V 6 /7
    at V8 / 9 , i get about 0 to 4mv..the meter just kind of jumps around--it wont settle down on a number .
    Any thoughts ??
    TP13 is 290vdc at "C" so that looks ok according to the scem.
    Attached Files Attached Files
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    What resistance do you measure across C45 and C46?
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    1,682
    Received: 67/0
    Given: 10/0
    Which two are red plating and which two are not? V6 and V8 share a cathode resistor and bypass cap, as do V7 and V9. That 4 output/2 output switch and it's pal 3w 100K R84 are worth a look also, since it is how two of the tubes get their cathode grounds.
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    v6 / v7 sockets are tubes going red.
    i just found something..R84 tests shorted in circuit..but out of circuit tests 100k . both ends of r84 are going to ground no matter where the half pwr is set . R 84 has to be shorted ?? or am i missing something ...
    the half pwr switch tests ok
    R83 / R85 OK
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    If the resistor checks good out of circuit it's good. The half power switch switches out 2 tubes by adding the 100k into the cathode path of those tubes. The switch shorts across the resistor for 4 tube operation. If your problem was there, V6 & V8 would be red plating instead of V6 & V7. I believe the problem is that 280vdc at pin 2 of V6 & V7. You need to find out where that's coming from. That's why I asked the resistance across C45 & C46. Even if it's not the caps themselves (since you changed them), there may be another current path there- a solder bridge, debris, socket issue, etc.
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    ok--sorry i missed that post-i will measure those here in about 30 minutes----in circuit right?
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    Yes, in circuit. Basically, we want to know if the plate voltage from V5A is somehow leaking over to the grids of V6 & V7, whether through the cap or some other means. Mostly interested in the resistance reading across C45, but comparing to C46 gives us more data.
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    220k and 240k
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,632
    Received: 559/1
    TP10, TP11 are the 120 ohm cathode resistors for the power tubes. Either of them shorted to ground?
    Your caps from the PI to grids may not measure shorted, but can still leak DC when facing hundreds of volts.
    Lift C45 from the circuit and see if the voltage goes away.
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    tp10/11 are not going to ground.
    ill have to pull the board again to pull c45
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    Have you checked resistance from pin2 of V6 or V7 to ground? Should be approx. 150K.
  12. #12
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    V6/7--the meter slowwwwwly creeps up to around 120- 125k ? this is over 10 or 15 minutes until the meter times out and shuts off
    V8/9 instantly measure 150k.
  13. #13
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    c45 removed--still have 230 vdc there at pin2
    so its maybe something to do with the v5 area... ??
  14. #14
    30,632
    Received: 559/1
    Start looking for conductivity or foreign material on the board in that area. Also look for a tip of a component lead nearby touching that trace. If so, trim it back. Follow the trace from pin 2 to anywhere it goes, looking for anything along the sides of that trace somehow touching it.
  15. #15
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    752
    Received: 73/1
    Given: 47/0
    Lift one end of r76 and r78. Is the voltage still there?
    (Assuming you already pull those tubes)
  16. #16
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    Quote Originally Posted by Valvehead View Post
    Does R73 measure 150K ? Does one end measure zero ohms to ground?
  17. #17
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    All looks good.
  18. #18
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Quote Originally Posted by SoulFetish View Post
    no---no volts at pin 2
  19. #19
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    yes and yes
  20. #20
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    So with C45 removed, you still had 230V at the grids of V6 & 7 ?
    But with R78 & R79 lifted it disappeared?
  21. #21
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Yes sir
  22. #22
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    Sounds like maybe board leakage, not sure from where.
    You still have the EL84's out?
    Earlier you said 280V at the grids, now it is 230V?
    Point C is 290V? How about pin1 and 6 of PI tube?
  23. #23
    Jan 2016
    Massachusetts
    752
    Received: 73/1
    Given: 47/0
    After you report back with the voltages g1 was asking about, I want you to try something..
    Pull the Phase Inverter tube, solder r76 and r78 back in circuit, and power back on. What's the voltage at the grids now?
  24. #24
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    ok--i was measuring wrong--sorry--
    el84s out , PI in , all resistors / caps in
    v6 220v
    v7 220v
    v8 0v
    v9 ov
    point C 355vdc
    PI tube pin 1 353v
    pin 6 354v
  25. #25
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    PI pulled , el84s pulled
    v6 258v
    v7 258v
    v8 0v
    v9 0v
  26. #26
    Jan 2016
    Massachusetts
    752
    Received: 73/1
    Given: 47/0
    Okay. Just in case you measured something wrong, replace the coupling cap feeding those two grids. Its cheap and thats the logical source of the problem. Report back
  27. #27
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    I replaced the .1 caps before
  28. #28
    Jan 2016
    Massachusetts
    752
    Received: 73/1
    Given: 47/0
    Okay.
    When you power up are those voltages present on the grids immediately or do they climb to those voltages after some time?
  29. #29
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Okay.
    Ok... i just got back from vacation last night. Ready for the madness ? I powered it up to test just now .... and now I have 15 vdc at the grids of V6-7 and 0vdc at v8-9................yep !
  30. #30
    May 2010
    Sioux Falls, SD
    5,312
    Received: 258/0
    Given: 221/0
    Are there any signs that something might have been spilled in the amp? I wonder if there was moisture somewhere that has dried out- maybe under a socket or something? I might hit the board with some compressed air and/or hair dryer. That, and a thorough inspection.
  31. #31
    Jan 2016
    Massachusetts
    752
    Received: 73/1
    Given: 47/0
    Well I’d say that’s progress! Only thing is you came back from vacation a little early. Go away for another two days or so, then come back and those voltages should be right we need them to be.
  32. #32
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Absolutely stumped here....
    I did a hail mary and installed some new caps and resistors tonight ..i dont know what else to do at this point ? I cleaned the sockets and pcb with alcohol and contact cleaner..i dont see anything wrong anywhere. No cracked joints or lifted traces...no solder blobs or hairs .
    So everything from the out of the plates of V5 is brand new ....also replaced R3 / c3 / c4 . All grounds check good . Ive worked through the circuit checking continuity .
    same result = V6/7 super high volts ............v8/9 nothing .
  33. #33
    Aug 2017
    Portland, OR
    345
    Received: 33/1
    Given: 36/1
    I think Mercury is in retrograde until Sunday. Still needs two more days.
  34. #34
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    "Absolutely stumped here...."
    It appears that the PCB itself is bad.
    Have you tried contacting Orange for a replacement?
  35. #35
    Old Timer
    Feb 2007
    Iowa
    1,325
    Received: 4/0
    Given: 2/1
    Quote Originally Posted by Jazz P Bass View Post
    no, but i can try that
  1. Bias Problems in a New Build
    By Just Mike in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2014, 01:23 AM
  2. Bias circuit problems...
    By Colonel_Sanders in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-18-2008, 10:05 AM
  3. TSL100 Bias Problems
    By bmd in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-30-2008, 01:09 AM
  4. Bias Problems With Marshall DSL100
    By wakeskater in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-19-2007, 12:43 AM
  5. Torres bias kit problems
    By strat100 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-19-2007, 11:44 AM
