Results 1 to 5 of 5
Thread: Fender Reverse Wound
    Lifetime Member
    Nov 2006
    51
    Hello!
    I just wanted to know when and how much Fender used a reverse wound pickup as the middle pickup. (To create the humbucker effect with the other 2 pickups). So when and how ofted did Fender use this tecknic?
    Thanks fro your commenrts!
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,080
    Received: 18/0
    Given: 11/0
    Middle pickup you must be referring to a strat , In strat's & tele's i'm not sure if they ever used the rw/rp in any of there US standard series guitars other than Texas special kind of pickups . other Fender guitars had rw/rp .
    Lifetime Member
    Nov 2006
    51
    Yes. I meant to say Strat Pickups. I was just wondering if the rw/rp pickups (middle pickup) were only on a couple of different strats or the majority of them. Is it concidered a standard feature now? Thanks!
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,298
    Received: 200/21
    Given: 201/9
    That didn't come into play until the 5 way switch.
    The 5 way didn't appear on strats until mid 70s?
    RWRP?
    I've read that it started in Fender Japan around 1985-ish.
    Not sure about that.
    The early model Reissue strats still come non-RWRP.
    Maybe someone else has more info?
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Senior Member ReWind's Avatar
    Sep 2011
    Colorado Springs
    308
    Given: 1/0
    None of the vintage Strats had a RWRP middle or a 5 way switch.
    Strat pickups are just about the easiest pickups to reverse electrical and magnetic polarity of, though, so it's a quick mod.
  1. Fender reverse taper volume pots
    By Xris in forum Guitar Amps
    Last Post: 09-11-2015, 12:56 AM
  2. Why does Fender label diodes in reverse?
    By Randall in forum Theory & Design
    Last Post: 08-16-2013, 06:08 AM
  3. Reverse wound vs reversed electrical polarity
    By kayakerca in forum Beginner/ Hobbyist
    Last Post: 07-24-2011, 07:10 PM
  4. reverse wind vs. reverse polarity
    By Jukers in forum Pickup Makers
    Last Post: 04-05-2010, 01:53 AM
  5. Reverse wind/reverse polarity question...
    By Neal in forum Pickup Makers
    Last Post: 01-20-2010, 01:30 PM
